| Forum topic by juniorjock | posted 261 days ago | 507 views | 0 times favorited | 14 replies | ![]() |
261 days ago |
I wanted to ask if anyone uses their shavings from their planer and jointer as mulch for garden paths? I guess my main concern would be if it would attract ants and termites, etc. I’m not sure but I think with the shavings being so fine, they’d be easily tracked into the house (especially when wet) I’ve been using cyprus mulch and it does great. No bugs and lasts a good amount of time. I’m just trying to find a use for the shavings instead of trashing them. -- JJ...... I guess you could say I'm a 54 year old "juniorjock". — Make things with wood. |
261 days ago |
I tilled a bunch into my garden spot over a year ago and I let it sit fallow last year. I’m going to plant this year. I hope that it loosens up the soil a bit. We live in sandy Delaware. Where the whole state is a gigantic sandbar. -- What happens in the workshop stays in the workshop. No wait that doesn't sound right. Karson Southern Delaware karson_morrison@bigfoot.com † |
261 days ago |
It certianly won’t hurt anything if the pathway is to be more or less permanent. Good luck Bob -- A mind, like a home, is furnished by its owner |
261 days ago |
I dump my shavings down the path that goes through the forest out back. It works great for the same reasons Bob#2 stated. The little red squirrels love it, as do the field mice and song birds…...............not much grows through it and it keeps the forest exactly where I want it…...........off of my path. |
261 days ago |
Bob Thanks for the info. I’d heard about the nitrogen problem. But, it’s a great reinforcement for this growing season. -- What happens in the workshop stays in the workshop. No wait that doesn't sound right. Karson Southern Delaware karson_morrison@bigfoot.com † |
261 days ago |
Walnut works great as a vegetation killer. I like to sweep it into the cement seams. |
261 days ago |
I forgot to mention Black Walnut . Thanks Marc. Bob -- A mind, like a home, is furnished by its owner |
261 days ago |
Karson, Use some gypsum also, it prevents the clays from hardening. Wood shavings go into the compost bin when they do not have paint chips with them as well as straight into the fall tilling of the garden. -- Never board, always knotty, lots of growth rings |
261 days ago |
If you are using it just as a path, I wouldn’t see that as being a problem since you probably don’t want to grow things on your walk way. I’ve been using sawdust and shavings to cover the path my dog makes when he runs. This keeps the yard looking better (since it defines the path) and keeps him cleaner (since he isn’t running through mud; dust I can deal with). The nitrogen problem is a relevant one. However, if you use a good amount of other compostable materials you can add scraps and sawdust to your compost bins. The trick is to have multiple bins that you rotate through. Our set up is two bins, one that we use this year and one that we put things in to use next year. Due to the amount of stuff we add to them (because we compost a lot) we are thinking of adding another one. A good mix with the scraps and dust should be green grass clippings, brown leaves (every fall!), and produce cut-offs (including egg shells). We’ve been doing this for a couple of years and have gone from clay that can’t grow grass to a vegetable garden that we have to give away things from! ~DB -- He said wood...http://hickbyassociation.blogspot.com/ |
260 days ago |
Pretty much all my saw dust goes onto the garden and my neighbors garden to keep weeds down. a little of it gets turned in. i’ll have to mention urea to the wife when planting is getting close. -- Talent on Loan from God - Rush Limbaugh ----------www.genesiswoodworks.com---------- |
260 days ago |
All my shavings and chips go on mulched paths. If you give any shavings to folks that want to use as animal bedding do not give them walnut shavings – will cause serious issues with horses. -- Those that say it can't be done should not interrupt those who are doing it. |
184 days ago |
I need to convert wood shaving pounds to yards, can anyone assist me. Joe |
184 days ago |
Hey Joe -- Jim from Heirloom Woodshop, custom furniture ,maker, woodworking school, heirloomwoodshop.com |
184 days ago |
I’m not sure if this will help or not but it may give you a starting point. http://www.blurtit.com/q403580.html -- JJ...... I guess you could say I'm a 54 year old "juniorjock". — Make things with wood. |
168 days ago |
yep, they’re ok -- JJ...... I guess you could say I'm a 54 year old "juniorjock". — Make things with wood. |
| Forum | Topics |
Woodworking Skill Share
2928 |
3961 |
258 |
955 |
226 |
Woodworking Trade & Swap
623 |
Coffee Lounge
2398 |
LumberJocks.com Site Feedback
524 |
