Can't stand plywood.
Forum topic by RussellAP posted 01-07-2015 08:21 PM 3651 views 1 time favorited 90 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
3103 posts in 2157 days
01-07-2015 08:21 PM
There are definitely uses for plywood, but unless I have a lot of area to cover, I prefer to glue up some 1×8’s for my panels.
I’m recreating this from the picture and haven’t used one piece of plywood yet.
I find that using a biscuit joiner and Titebond II gives a stronger build than plywood. Takes more time but gives a stronger finished work.
One of the main reasons I don’t use plywood is that I have a small shop and having those large pieces takes up room, plus they are hard to work with and if you make an error they are expensive to replace.
I know some of you have nice large shops and think I’m crazy, and maybe I am.
Which do you prefer for your cabinets?
90 replies so far
View SuperCubber's profile
SuperCubber
1015 posts in 2155 days
#1 posted 01-07-2015 08:41 PM
Plywood forever!
-- Joe | Spartanburg, SC | "To give anything less than your best is to sacrafice the gift." - Steve Prefontaine
View Rick Bailey's profile
Rick Bailey
247 posts in 1233 days
#2 posted 01-07-2015 08:51 PM
Plywood.
Doesn’t move like hardwood.
-- I'll bulid your dream,you tear it down.
View NoThanks's profile
NoThanks
798 posts in 1399 days
#3 posted 01-07-2015 08:56 PM
A professional realizes that their time is worth way more than the labor to glue up pcs, and it’s far cheaper to use ply.
All you are doing is taking money out of your pocket!
-- Because I'm gone, that's why!
4823 posts in 2364 days
#4 posted 01-07-2015 09:12 PM
Plywood here…..
View OSU55's profile
OSU55
1460 posts in 1860 days
#5 posted 01-07-2015 09:54 PM
If painting, definitely plywood. Recreating the piece shown, plywood, since face frames are used. If I wanted just edge frames, probably solid wood for the shelving – I don’t like edge banding. The entertainment center would be ply, maybe solid wood for the top shelving if edge framed.
As mentioned, if I were doing it for $, ply all the way.
View ChuckC's profile
ChuckC
826 posts in 2806 days
#6 posted 01-07-2015 10:40 PM
I feel the same as you about plywood. I hardly use it. If I made the stuff for a living I may think differently though.
View Moron's profile
Moron
5032 posts in 3764 days
#7 posted 01-07-2015 10:59 PM
Saying plywood is better then wood, or wood is better then plywood, is like saying a potato chip is better then a potato, or a grape better then a bottle of wine.
Plywood can be as rude as the nose of a pig, and just as tough, ..... not all plywoods are created the same and some are ugly, others as sweet as wine.
I not only like plywood, I love it when its pancake flat, and comes pre-finished : )
View dhazelton's profile
dhazelton
2648 posts in 2167 days
#8 posted 01-07-2015 11:03 PM
Plywood is dimensionally stable. Real wood is not.
View Charlie's profile
Charlie
1100 posts in 2157 days
#9 posted 01-07-2015 11:08 PM
HINT: for the entertainment center…
Because you’re using 3/4” thick stock for the back, plan on installing a mount for the flat panel TV and get it off the stand.
Why?, you ask…
Because it’s a PAIN IN THE BUTT to dust with the TV on a stand. Seriously. I have a similar piece of furniture here. After I mounted the TV on a mount in that recess I was like… “Why didn’t I do this in the first place?”
And plywood….. it’s just another option for me. Depends what I’m doing. It IS hard to handle in a small shop and if you work alone all the time (like me). That’s why I have my cuts planned before the sheets ever come home and my breakdown table is set up and ready. The sheets come out of the vehicle and slide onto the breakdown table. Circular saw and edge guide. Break ‘em down into manageable pieces.
I would RATHER just work with solid wood. But if I just need some cabinets and nobody is going to see the sides…. plywood. If I’m building a table or furniture piece (or a new EASEL!) then I like solid wood.
View pmayer's profile
pmayer
1015 posts in 2936 days
#10 posted 01-07-2015 11:13 PM
I use plywood by default for cabinet carcases because I lack both the time and money to build them out of hardwood, and I also don’t see the benefit of using hardware for this in most cases (where the asthetic warrants this, such as a Krenov style cabinet, then by all means use hardwood). It would be an unusual cabinet application that requires more strength than plywood. Working with plywood in a small shop just requires a decent guide (shop made is fine) for your circular saw and some saw horses. For less than $100 you can have a good circ saw, adequate blade, and a guide that will give you a great cut quality with virtually no chipping. For an approach even easier than saw horses, lay the plywood on top of a sheet of 1” or thicker XPS insulation that sits on your shop floor (or driveway) and it serves as a great sawing platform.
Rick Dennington
5656 posts in 3065 days
#11 posted 01-07-2015 11:29 PM
I refuse to answer on the grounds that might tend to incrininate me…....!!!!!
-- " Don't pet the sweaty things, and don't sweat the petty things."
Moron
#12 posted 01-07-2015 11:30 PM
I wouldn’t say that one was better then the other, without knowing where it was being used, and without speaking to the person who wanted to own it, and what the purpose is, I think its always good to have an understanding that not all things are measured equally, that there are just varied degrees of being right and that sense where the fulcrum sits, is always owned by the person who signs the cheque.
Just because some one hands you a cheque
Doesnt mean you have to accept it : )
Moron
#13 posted 01-07-2015 11:37 PM
Plywood is stable
Real wood is not
really ?
If your sitting on your donkey and watching the TV,
either one works so far : )
RussellAP
#14 posted 01-07-2015 11:38 PM
For who ever said it was cheaper to use plywood, The plywood at Lowes for this job would run me $50 a sheet and I’d have to have Lowes cut it for me because I can’t handle a 4×8 sheet. Just too heavy and if you drop it on a corner, it’s ruined. Using 6’ and 10’ pine 1×8’s is much more economical. I glue up just what I want and if something happens to it, I can rip the bad piece out and put in another for very little. The depth on these pieces is not all that much, so I rarely have to glue up more than three boards to make a side. The backs are plywood, but that is all.
View Monte Pittman's profile (online now)
Monte Pittman
27663 posts in 2209 days
#15 posted 01-07-2015 11:50 PM
If you use the high-grade pine boards from the box stores, it’s not cheaper than plywood. I know at Menards, you can get the cheaper pine boards, but I wouldn’t use them for a customers project.
Mathematically, plywood is stronger than pine of equal thickness. But, you need to use the appropriate type plywood as well.
-- Mother Nature created it, I just assemble it.
showing 1 through 15 of 90 replies
