cutting veneers with a bandsaw
Forum topic by stillgotallmydigits posted 01-07-2015 06:36 PM 1755 views 1 time favorited 19 replies Add to Favorites Watch
View stillgotallmydigits's profile
stillgotallmydigits
34 posts in 1681 days
01-07-2015 06:36 PM
Topic tags/keywords: bandsaw blade question
Hi all, I am just about convinced i am inept at setting up my Rigid 14” bandsaw. If I am cutting material less than 1/2” thick everything runs just great, but if I attempt to cut thicker stuff the blade drifts all over the place, even with the fence in place. I have tightened the blade as tight as I can by hand and tried different thickness of blades with zero luck. I am bummed because the primary reason I bought this thing was to slice veneers. Any ideas would surely be appreciated!!! Thanks
-- Steve, So.Cal.
19 replies so far
View jmartel's profile
jmartel
8237 posts in 2353 days
#1 posted 01-07-2015 06:52 PM
Look up a video on youtube called Alex Snodgrass Bandsaw Clinic. Should get you working. You also may have a dull blade.
View shipwright's profile
shipwright
8166 posts in 3001 days
#2 posted 01-07-2015 07:33 PM
You need the right (sharp) blade, a tuned saw, and the drift accounted for.
For cost / quality ratio, I like Diamond Sterling blades but there are lots of good ones.
jmartel
#3 posted 01-07-2015 07:38 PM
You shouldn’t have any drift with a sharp blade and proper setup. No need to account for it if it isn’t there.
shipwright
#4 posted 01-07-2015 10:05 PM
Absolutely correct, Jeff ….. in a perfect world.
I’ve had enough surprises to hedge my bets and mention blade drift anyway.
By “accounting for it” I guess I meant having the fence set so it cuts parallel to the edge of the board. If that is dead 90, ......... nice! But if it’s 85, that’s OK too, if it’s accounted for. :-)
View johnstoneb's profile
johnstoneb
3060 posts in 2375 days
#5 posted 01-07-2015 10:18 PM
If you are cutting a lot of veneer spend the extra money and get a carbide tooth blade. Olson makes a very good one and timberslicer is an excellent one. They cut exceptionally smooth and no set. They cut straight well worth the extra money. I have the olsen I think the timberslicer might be a little bit better but is also a little more expensive.
-- Bruce, Boise, ID
stillgotallmydigits
#6 posted 01-08-2015 06:36 PM
That’s a great video jmartel! Thanks! I will go do the setup as he described and see what I get….I’ll report back with my success or failure…:)
-- Steve, So.Cal.
View Woodbum's profile
Woodbum
835 posts in 3268 days
#7 posted 01-09-2015 04:55 PM
I use Woodslicer blades from Highland Woodworking (Hardware) in Atlanta. I only use them for resawing, and never for curve cuts and they work great. I must be bandsaw challenged, because no matter how many times I set up my 14” Jet according to Michael Fortune and several others out there, I still get drift. So I finally said to hell with it, and set it up as accurately as I can and set my Carter MagFence II resaw fence cantilevered to account for the drift and I get great results every time. Go figure. Your blades must be sharp, with the set on the teeth still accurate, using a low (3-4 tpi) with big gullets for sawdust removal. Alex’s video is a good reference. The Woodslicer is pricey to some, but not nearly as pricey as a carbide blade. Just my personal opinion based on my experiences.
-- "Now I'm just another old guy wearing funny clothes"
stillgotallmydigits
#8 posted 01-09-2015 11:12 PM
thanks for all the great tips! Well after watching that video I went down and performed all the adjustments…must say I really like the look of the ball bearing guides v. the plasticky squares on my Rigid. Anyway I managed to cut a 2” slice of maple at very slow speed and it looked pretty good. If I went faster or to a thicker matl. the blade wanted to pull in towards the fence. All I can surmise now is that I must have dulled or damaged my blade from the earlier misadjustments?
-- Steve, So.Cal.
View RT31's profile
RT31
54 posts in 1860 days
#9 posted 01-09-2015 11:24 PM
+1 on the woodslicer Blade.
And there may or may not be something wrong with your current blade. IDK. However, it could just be that it isn’t the right blade for what you want to do.
What blade is on there now?
stillgotallmydigits
#10 posted 01-09-2015 11:28 PM
I think its an Olsen…got it at Rocklers here in So. Cal. and they don’t carry cheap stuff! Can’t think of what else to do right now but try a new blade. I’ll see if I can find one o those woodslicers. Mostly I want to use this saw for resawing wood for inlays….let’s see if the new blade and proper adjustment helps!
-- Steve, So.Cal.
jmartel
#11 posted 01-09-2015 11:42 PM
Woodslicer is only sold by Highland woodworking. Timberwolf blades are also very well regarded and you can find those in more places. Most likely, you are going to have to order it online somewhere.
stillgotallmydigits
#12 posted 01-09-2015 11:44 PM
thanks Jmartel!!
-- Steve, So.Cal.
View spaultedsteel's profile
spaultedsteel
8 posts in 1472 days
#13 posted 01-10-2015 12:09 PM
I have the same saw and had the same goal, to cut veneer. With Carter guides and a woodslicer blade, the saw performs quite well, if you don’t push it.
-- dave,missouri, http://www.spaultedsteel.com
spaultedsteel
#14 posted 01-10-2015 12:12 PM
View Logan Windram's profile
Logan Windram
347 posts in 2665 days
#15 posted 01-10-2015 01:26 PM
I’d guess dull or poor quality blade and drift. In theory you can setup and adjust for drift, but I think it is just easier to adjust my fence for the drift. Also think about feed rate, that is a small saw, cutting hardwood veneer will be a slow steady process. Tune up the saw, and go slow… I’ve gotten 16th inch veneers easily with that saw, may have been able to go much thinner is needed.
