Problem with #4 Iron upgrade
Forum topic by Cam posted 260 days ago 193 views 0 times favorited 6 replies Add to Favorites Watch
View Cam's profile
Cam
16 posts in 275 days
260 days ago
Topic tags/keywords: plane
I have a 1910 or so stanley #4 that I’ve cleaned up. When I put in a new Lie Nielsen Iron, the frog does not slide far enough back to allow the blade to fit through the throat. I took everything apart while cleaning so I know its at the limit. Is taking a bit out of the casting (3/16 or so) comen/ nessesary for this upgrade?
View Cam's profile
Cam
260 days ago
c’mon, someone must have dealt with this before
View Moai's profile
Moai
721 posts in 290 days
260 days ago
the problem could be you bought an iron for their planes (0.140” inch thick). They sale irons especifically for Stanley-Record like your (0.095” inch thick)
The other option is to return it and get a Hock Iron.
-- Francisco Luna, San Francisco Bay Area.
View Cam's profile
Cam
259 days ago
I got the replacement type, so thats not it
View Gofor's profile
Gofor
109 posts in 684 days
259 days ago
Is the problem the iron hitting the back of the mouth or that the frog will not move back far enough? (I only have ones going back to the 20’s and have not had a problem with the Hock Iron. They will not fit with the bevel up. Make sure the bevel is down towards the frog.) Your estimate of 3/16 makes me think you have the iron upside down as that is thicker than the thickness of the Hock Blade.
Go
-- Go http://ncwoodworker.net/pp/showgallery.php?cat=500&ppuser=730
View Cam's profile
Cam
256 days ago
I ended up filing a little bit of the frog away allowing it to slide back on the bed. Now she works great! (bevel down of course)
View Moai's profile
Moai
256 days ago
