More Sketch Up help needed, at wits end.
Forum topic by thelt posted 261 days ago 278 views 0 times favorited 16 replies Add to Favorites Watch
View thelt's profile
thelt
168 posts in 277 days
261 days ago
I am trying to put the plans to the gun rack I posted in my projects to a sketch up drawing. I’ve got the Storage box drawn out. Now I need to add the uprights (1 X 3 X 3/4). About ready to draw it on paper and forget it on sketch up.
Storage Box
When I try to put the uprights in the drawing they show up in front of the box instead of the cut-outs on the back of the box. I’ve literally worked on this for hours and can’t get them in right. Sometimes they will show up in the middle of the box. It just isn’t working for me.
box2
This is what I get most often on retries. I start out with the proper dimensions 47 X 3 X 3/4 but when I do the push pull this is how it comes out (above). In different segments.
If one of the sketch up guru’s would like, I can email the .skp file.
Very humbled
Frank
-- There are three signs of old age. The first is loss of memory. I forgot the other two!
View ChicoWoodnut's profile
ChicoWoodnut
895 posts in 712 days
261 days ago
Hi Frank,
I’ll pm you with my e-mail. I have about an hour before I have to be at work :)
View DaveR's profile
DaveR
1527 posts in 617 days
261 days ago
Scott may have fixed this already but from the image it looks to me as if you haven’t made components of the parts you are drawing. You need to draw each part as a component to keep them separated from each other. The face of the upright is being split by the shelf so there’s two surfaces—actually more than that because of the intersections of top and bottom edges. If the shelves were already components the upright wouldn’t be affected by their geometry.
Edited to add: I zipped this out based on your images. I probably didin’t get all of the dimensions right but it’s the idea, right? So, you can see in this screen shot that each of the components has been selected and has a blue bounding box. Each part is discreet from the rest just as the wood in your real project was discreet parts. And just like the real parts. if you lay one piece up against another, they don’t change each other. Of course glue changes that but I hope you get the idea.
-- Until you spread your wings, you'll have no idea how far you can walk.
ChicoWoodnut
261 days ago
Dave is correct. You did not make components. I created a new file. There are three components. They are all mirror images of each other. Try editing one and see what happens to the other.
Sides
Shelf
Uprights
Check it out. This will give you a good feel for the power of components.
DaveR
261 days ago
Ah, Scott. We’re on the same track. Fortunately we’re going the same direction, too. :)
ChicoWoodnut
261 days ago
To work?
DaveR
261 days ago
I guess I’m in the lead because I’m already there. Have a great day.
View sandhill's profile
sandhill
608 posts in 821 days
261 days ago
I am as dumb as a box of rocks when it comes to this program. I came across someone that has a web site called sketch up for woodworkers. Here it is.
http://sketchupforwoodworkers.com/
-- Sell it here> http://woodworkerslist.com
thelt
261 days ago
Thanks, guys. I see what you’re doing, now gotta learn to do it for myself. Thanks again.
ChicoWoodnut
261 days ago
Stay tuned, I feel a tutorial coming on. Gotta run to work though.
Hah!
DaveR
261 days ago
Scott, are you going to do one?
There is this although there’s no pictures. And of course there’s this one.
View PurpLev's profile
PurpLev
2762 posts in 546 days
261 days ago
I’ll second (or third) Scott, and Dave, components is the way to go, the sooner you’ll get used to working with it, the easier and faster your sketchup work will become.
DaveR
261 days ago
And don’t make groups. Use components.
thelt
261 days ago
How do you change the dimension readout from 64’s to fourth’s or eight’s?
sandhill
261 days ago
To late to delete my message but I think this guy is giving out some incorrect information so if you use the tutorial I would verify his teachings with someone that knows sketch up. Sorry for the possible misleading information.
DaveR
261 days ago
It depends. the dimension tool will give you the dimension to the nearest units selected under window>Model Info>Units. If a dimension is, say 1/4”, it will be displayed as such even with Precision set to 1/64”. If you just want to know to the nearest 1/8” or 1/4” then set Precision to that. If you have Precision set to 1/4”, though, you could end up with some major problems due to rounding errors.
My opinion is that you should draw to higher precision than you’ll work in the shop.
View Handidad's profile
Handidad
25 posts in 271 days
260 days ago
I’ve just spent some time trying to do a sketchup of a workbench, and it was a very time consuming frustrating ordeal. I wouldn’t have persisted if I had to make money on it.
Some tips that I discovered;
When moving a component to add it to an assembly, put the selection point dot on a surface or corner that will meet with an edge on the component. It might be necessary to rotate the view.
After selecting the move tool and component to be moved, press and hold the up, left or right arrows to keep the movement in green, red or blue axis directions.
Yes make components of everything even assemblies of components that have to be replicated.
