OK, I NEED some sketchup help.....paging Bob and the other experts.....
Forum topic by Ryan Shervill posted 03-11-2009 05:05 AM 3208 views 0 times favorited 19 replies Add to Favorites Watch
View Ryan Shervill's profile
Ryan Shervill
278 posts in 3781 days
03-11-2009 05:05 AM
Gentlemen…I’m at my whits end….can you please tell me how to make the following two shapes?
I need to do a flat-topped cone (or ANY cone would suffice)
I need to do a disc…but I need it to have a bullnose edge….picture cutting a 4” disc out of 1/2” or 3/4” material, then rounding over the edges with a round-over router bit…that’s what I need to draw.
Can anyone help me out?
Ryan
-- Want to see me completely transform a house? Look here: http://forum.canadianwoodworking.com/showthread.php?41055
19 replies so far
Ryan Shervill
#1 posted 03-11-2009 01:54 PM
Hey thanks! I have the cone now….but I can’t get the disc…..can you dumb it down a little more? I keep getting a “connot extrude a curved face”......I must be missing something.
Thanks for the help so far! :)
Ryan
Ryan Shervill
#2 posted 03-11-2009 03:59 PM
Maybe it’s me….when you say “Select face of the disc”, which face….the top/bottom, or the side? (I’ve tried both…but it ,may help me to narrow it down :) )
Ryan
View Handidad's profile
Handidad
27 posts in 3342 days
#3 posted 03-12-2009 06:28 PM
I’m learning sketchup myself, so I tried both methods. I think that Dave’s method needs is more complex and needs more steps, although it was amazing watching the follow me tool fill in the disk when the circle was touched.
Ryan Shervill
#4 posted 03-13-2009 04:10 AM
I really appreciate the help!
I STILL can’t get bently’s method to work though….it has to be me…..and it’s bugging the rap out of me. Bently, can you re-post with EVERY step dumbed down/explained so I can get some sleep tonight? :)
Dave, your way worked (thanks!), I just feel I need to learn Bentley’s way as well….it’s all about the learning curve :)
Ryan
View Chris 's profile
Chris
1879 posts in 3960 days
#5 posted 03-13-2009 04:30 AM
I love watching you guy’s teach each other. You are some of the best, most giving folks I know!
-- "Everything that is great and inspiring is created by the individual who labors in freedom" -- Albert Einstein
Ryan Shervill
#6 posted 03-13-2009 04:34 AM
Hey Chris, stick around…..I can show you how to screw up a bullnose..:)
Chris
#7 posted 03-13-2009 04:39 AM
I got you beat! I can screw up a straight line!! :)
Ryan Shervill
#8 posted 03-13-2009 01:35 PM
Thanks Dave. I go to bed and wake up to a video!
You are a huge asset to the board.
One ?: You said in your vid that you upped the faces on the circle from 24 to 48. Which menu allows you to do this?
Want another one? :)
Is there an easy way to apply edge profiles to a mitered frame? Take a picture frame for example….you have the four mitered pieces and run the outside edge over a chamfer, round, or ogee bit….that kind of profile.
I’m assuming you would have to make all four parts as rectangular components, apply the profile with the push/pull tool, then make the ends 45 degrees?
Thanks again!
Ryan
View Doug S.'s profile
Doug S.
295 posts in 3676 days
#9 posted 03-13-2009 03:36 PM
Dave
My first thought on the cone shape was to push/pull a circle into a cylinder then scale one end of it down to a point. But it looks like you cant get down to a single point with that method? I’m only able to get an increasingly smaller flat end. Is there a Scale trick that would let you shrink that end to a point?
-- Use the fence Luke
Doug S.
#10 posted 03-14-2009 01:01 AM
Dave
Is there a known problem under Vista?
When I start SU after installing the plugin I get this error message”
Error Loading File shapes.rb
No such file to load—parametric.rb
Doug S.
#11 posted 03-14-2009 01:09 AM
Never mind.
It’s another one of Vist’a annoying “Need Permission” things. This OS needs a popup blocker!!
Handidad
#12 posted 03-14-2009 03:20 AM
Doug,
I was able to draw a circle and then put 2 lines (diameters) across the centre. Using thepush/pull tool on the centre dot I was then able to pull it up into a cone. The only problem was that it was a hollow cone, not a solid.
Doug S.
#13 posted 03-14-2009 08:27 AM
Dave
Is there a URL problem with that last one? I keep gretting sn error message:
IE cannot download parametric.rbn from www.crai….......
Doug S.
#14 posted 03-14-2009 12:29 PM
Whack-a-mole time. Different error message but now it also wants mesh_additions.rb
Handidad
#15 posted 03-14-2009 01:59 PM
Sorry about the mistake,
Doug,
It is the MOVE tool That is used on edges or points. THe push/pull tool is for surfaces.
This same technique can be used to put a peaked roof on a square or rectangular box if there are diagonals corner to corner.
