I don't think I get it - Thin Kerf Parting Tool
Forum topic by dmann posted 261 days ago 234 views 0 times favorited 5 replies Add to Favorites Watch
View dmann's profile
dmann
75 posts in 704 days
261 days ago
Topic tags/keywords: woodturning parting tool
So after having a regular old double sided 3/16” parting tool for a while I picked up a thin kerf tool to make pen turning a little easier. Well that was the plan anyway :)
Can someone explain to me the proper way to present this to the wood?
I am used to using a regular parting tool so I figured I would attempt to use it that way. I tried to present it angled edge down with the angled edge rubbing and ease into a cut but it started digging into the wood and I had to pull it away. It left a very jagged rough cut.
I flipped it over so the angled edge was up but I decided agianst presenting it to the wood, it just looked like it was going to dig in and I was already gun shy from my first attempt.
Any suggestions?
-- David / Durham, NC
View lew's profile
lew
4496 posts in 652 days
261 days ago
I’ve never used one but I thought it would be the same as using a skew chisel to make a groove.
With the skew, I use the toe (point) and ease it in at about the 10 o’clock point on the work piece.
View papadan's profile
papadan
465 posts in 265 days
260 days ago
I’ve never seen such a short handled lathe chisel. My guess would be that is causing the chatter by not having any leverage to hold it steady. What brand is that cut off tool?
-- Dan-- Info for all @ http://www.hoistman.com
View lew's profile
lew
252 days ago
Found this YouTube. Not exactly what you asked about but maybe it will help
http://www.youtube.com/watch?v=8Joo-cBzsjQ&feature=related
View trifern's profile
trifern
7894 posts in 664 days
252 days ago
Hey David, this is how I use mine.
The angle may not be exactly right. I was holding it with my left hand while taking the photo with my right. Hope this helps.
dmann
252 days ago
Papadan – there are a few manufacturers that make it, I got mine from Penn State Industries but I’ve seen similar versions in the catalogs from other popular vendors.
Lew and Trifern thank you for the visual aids, I think I get it now. My parting tool is right out of the box, I am thinking I need to spend some time grinding off the front corner and coming up with an angle I can comfortably work with. I’ll give it a try this weekend and report back.
