Shooting board question(s)
Forum topic by Betsy posted 261 days ago 432 views 2 times favorited 5 replies Add to Favorites Watch
View Betsy's profile
Betsy
2386 posts in 793 days
261 days ago
Topic tags/keywords: shooting board
I’m now banned from the shop until tomorrow night while the finish dries on my cabinet project. So I thought it would be a good time to drag out my shooting board and clean up a few box sides.
First, I have to tell you that I made about 12 boxes 3 or 4 years ago. Only a couple turned out well enough to give away. The others got relegated to a shelf and have been there since. But last weekend, I got a wild hair and pulled them down. I was right – they were not very good. So I took the band saw to them and cut them apart. So now I have all these parts that I can make smaller boxes with.
Secondly, when I cut the boxes on the band saw, I did not pay any particular attention to cutting them straight. I just free handed them through the saw. I cut out all the splines, etc.
So now I have a bunch of box sides that are not straight. Hence the pulling out the shooting board. Hand tools are so much fun.
But now to my problem. Despite the pictures I’m about to post, which make my hands look like dinner plates, my hands are not so big. The result is I’m having some trouble holding my work piece on the board securely as I pass the plane over the edge.
Well, I was going to post some pictures. But I can’t get the links to work. Usually when I hit copy (HTLM) the word “copied” shows up and I can paste it into the forum/blog space. But not tonight. Not sure why – if you have an answer for that I’d be appreciative.
Anyway – back to my shooting board issue. Because I can’t hold the piece secure, I don’t get a good square edge. Now on my table saw fences, I can put a piece of sand paper to help hold the piece and it works well. But when I use this trick on a table saw – it is usually on much larger pieces. These are small pieces. So can I put a piece of sandpaper on my shooting board and it not interfere with making the piece square. In other words, since most sand paper is not perfectly even across the face – will it interfere with the process of squaring my boards?
And – how would you secure the paper? I’m thinking spray adhesive (just a little). But welcome your suggestions.
Thanks in advance.
Humm – just reread this and I just want to add that I didn’t want to paste sandpaper to my board until I had an idea if it would work. No sense messing up a good board.
Thanks
View lew's profile
lew
4496 posts in 652 days
261 days ago
Betsy,
Could you clamp the shooting board and box piece to a table top, as a unit?
I was thinking if you positioned the box piece, in place, on the shooting board then clamped the box piece, shooting board and table top all together with one clamp it might hold it securely enough to do what you need.
Lew
Douglas Bordner
3426 posts in 960 days
261 days ago
Betsy,
I have nothing to offer on the shooting board aspect of the question. I just built my first one a few weeks back, and am too much the novice to weigh in. On the posting question, however, I have noticed a similar difficulty of late with my Photobucket account (I’m a Macintosh guy, running OS X (10.4.11) on a PowerPC, using Firefox/3.0.7). I have just been highlighting the HTML code line and coping the line of code to the clipboard and pasting this into the blog/project/forum as the “copied” notification was not copying anything that would then subsequently paste.
Try Control-C, Control-V shortcuts (⌘-C, ⌘-V for Mac) or the Edit>Copy/Edit>Paste function in your browser to see that works for you as it does for me.
View oldnovice's profile
oldnovice
35 posts in 265 days
261 days ago
I have always relied on double sided carpet tape; typically 2 inches wide (don’t use just any double sided tape).
I have found that on very small pieces I need to be careful of how much I use since the pieces may break before the tape lets go. I use a roller to flatten out and get the tape on one side then I remove the other side of the tape attach the piece and then apply pressure. The bigger the piece the more pressure.
Oh yes, make sure that there isn’t too much dust on either piece (easier said than done in a woodworking shop)!!!
-- Hans in San Jose; "I never met a board I didn't like!"
Betsy
260 days ago
Thanks guys. Lew – I actually tried that with not much success – it was too cumbersom
Jose – I thought about carpet tape, but was worried about breaking my pieces. Some are pretty small. But I think I will give this a try and let you know how I come out.
Thanks again.
(Doug – I seem to be able to do the pictures now. It might have been that I needed to reboot my computer. Thanks)
View Derek Cohen's profile
Derek Cohen
48 posts in 865 days
258 days ago
Hi Betsy
I now use a non-slip surface on the fences of the shooting boards I build. This is made of a non-slip powder that is added to a little marine varnish. You could substitute fine salt. Just sprinkle it on with a shaker so that it falls evenly.
Add this to the fence, then square the fence on the shooting board.
There are a few articles on my website about building and using shooting boards. Here is one ..
Setting Up and Using a Shooting Board
A recent board I made for a customer ..
The article is here.
Regards from Perth
Derek
-- Building and Reviewing Tools at http://www.inthewoodshop.com
