4x4 TRUE UP!
Forum topic by rantingrich posted 01-07-2015 03:04 AM 1108 views 0 times favorited 3 replies Add to Favorites Watch
View rantingrich's profile
rantingrich
372 posts in 1309 days
01-07-2015 03:04 AM
I need to JOINT some 4×4 pine on my table saw since I don’t have a JOINTER. I need to true up some stocks. I got the best ones at Menards had but as you all know they are far from square and true.
I have seen and watched some videos where they use a so called SLED to make the first TRUE cut on a table saw for stock BUT not as deep as 4×4.
I could make a sled where the 4×4 sat on top of a 3/4 thick sled BUT that means my 10 inch TS and blade can not cut all the way through the 4×4 stock.
Any suggestion on how I can use a 10inch TS as a make true squared up cuts on 4×4 stock
-- Rich
3 replies so far
View TheFridge's profile
TheFridge
9249 posts in 1450 days
#1 posted 01-07-2015 03:31 AM
You have a planer? Make a sled for it?
rantingrich
#2 posted 01-07-2015 04:19 AM
No thats the problem no planner! No Jointer. just a table saw
-- Rich
View Rayne's profile
Rayne
832 posts in 1503 days
#3 posted 01-07-2015 05:15 AM
http://woodworking.formeremortals.net/2014/06/11/edge-jointing-with-a-table-saw/
You couldn’t make this, modified, on a 1/2” sled to cut through the 4×4?
