Green wood
« back to Woodturning forum
Forum topic by Mark posted 01-07-2015 01:24 AM 994 views 0 times favorited 4 replies Add to Favorites Watch
View Mark's profile
Mark
973 posts in 2180 days
01-07-2015 01:24 AM
Any of you folks HOLLOW turn green wood? Must produce some bazaar shapes.
-- Mark
View Druid's profile
Druid
1911 posts in 3001 days
#1 posted 01-07-2015 02:29 AM
Hi Mark, I haven’t tried turning green myself . . . Yet . . . But there is an interesting book on working with green wood titled
Green woodworking : handcrafting wood from log to finished product / by Drew Langsner – ISBN: 0878576894
There is a section on “boring” which may give you some useful information. I came across this at my local library, so you might want to take a look at yours to see if they have a copy.
One of the local turners near me does green bowls, which turn out as ovals once they are dried after being turned. Interesting items that seem to sell well.
-- John, British Columbia, Canada
View gwilki's profile
gwilki
227 posts in 1679 days
#2 posted 01-07-2015 02:44 AM
I turn quite a bit of green wood. Lately, most of it has been ash since the city is cutting them down by the thousands owing to the borer. I have done maple, birch, cherry and walnut green, too.
If you turn bowls relatively thin – 1/8 to 1/4” – to the final shape, they will warp nicely, usually, and not crack. Then a final sanding and finish. You can get some nice “potato chip” shapes.
You can also turn green as a twice turned bowl. You turn the shape green, but leave the wall thickness about 10% of the diameter. So, a 10” bowl has 1” walls. Then, you bag it or wrap it in paper and leave it for months. The plan is that it dries slowly, so it warps a bit, but does not crack. When it’s stopped losing weight, you remount it on the lathe and turn it to final shape and wall thickness.
-- Grant Wilkinson, Ottawa ON
View Wildwood's profile
Wildwood
2483 posts in 2340 days
#3 posted 01-07-2015 05:19 PM
Green wood is best you can get for bowl or hollow turning, bazaar shapes not always predictable. Depending upon how you cut a blank out of a log and orientate growth rings will different effects. Species & density also have affect on wood movement.
Although we all know wood shrinks when as it dries looking at this picture shows different shapes you can expect when cutting boards from a log.
http://www.turningtools.co.uk/wood2/wood_pics/shrinkage-14.gif
For bowls & hollow forms & grain orientation click on images at this link.
https://cooncatalleyturnedwood.wordpress.com/wood-information-2/grain-orientation-finding-the-bowl-within-the-log/#
Rough turning a green bowl or hollow form blank to a uniform thickness and letting wood go oval pretty standard and allow wood to dry enough for finial turning & finishing.
Turning green blanks thin not always a going to be successful, but don’t let that stop you from trying!
-- Bill
View Mark's profile
Mark
#4 posted 01-07-2015 08:26 PM
Thank you for the input gents. As always very informative.
-- Mark
