How do I measure a outside corner mitre cut?
Forum topic by EdsCustomWoodCrafts posted 01-06-2015 10:37 PM 1644 views 0 times favorited 15 replies Add to Favorites Watch
View EdsCustomWoodCrafts's profile
EdsCustomWoodCrafts
746 posts in 1249 days
01-06-2015 10:37 PM
Hello
I have a compound mitre saw and I want to cut a 45 angle ( I know how to cut a 45 bevel ) but I’m not sure what the measurement should be!!! Let me lay it out for you..
I want to put an outside trim on my workbench and width is 78” wgat should my measurement be to make sure the pieces meet up on the corner ??
Please help!!!!!
-- Thanks Ed “A bad day woodworking is better than a good day working. ~Author unknown”
15 replies so far
View Earlextech's profile
Earlextech
1160 posts in 2597 days
#1 posted 01-06-2015 10:41 PM
The short end of the cut should measure 78”. That’s all there is to it. The long end of the cut varies by the thickness of the trim.
View RussellAP's profile
RussellAP
3103 posts in 2193 days
#2 posted 01-06-2015 10:43 PM
What earl said, unless it’s crown molding. Believe me, you can’t get written advise on how to do crown molding.
MrUnix
6354 posts in 2105 days
#3 posted 01-06-2015 10:55 PM
Add twice the width (or thickness depending on how it’s being applied) of your trim.. if it’s 1/2”, then you would cut 79” (inside would measure 78”). 1” trim, add 2”, and so on. Although I usually cut a bit long and then sneak up on it a little bit at a time until it’s just right :)
View kdc68's profile
kdc68
2638 posts in 2183 days
#4 posted 01-06-2015 11:01 PM
If you have a miter on each end like this
45….........45
The long side is double the width of the trim….
Example: the trim is 2” wide, the short side is 78” and the long side measurement is 82”
v
v
Edit : MrUnix beat me to a good example
-- Measure "at least" twice and cut once
View greg48's profile
greg48
593 posts in 2664 days
#5 posted 01-06-2015 11:47 PM
To your credit Ed, once you start on a project there is no “dawdle” in your vocabulary. I suspect that by the time you receive any advice, your long past the need for it. MrUnix has good advice, start on the long runs in the front and close on the short runs in the back (sneak up on the closing lengths).
-- Greg, No. Cal. - "Gaudete in Domino Semper"
View Rick's profile
Rick
8899 posts in 2939 days
#6 posted 01-07-2015 05:30 AM
The short end of the cut should measure 78”. That s all there is to it. The long end of the cut varies by the thickness of the trim.
- Earlextech
He’s correct. How else could you do it? “Short End” (of the 45 Degree Mitre Cut) is the Outside Length of your Workbench, (78”) and the “Short End” Cut is the Outside Width of your Workbench.
I’ll assume you meant the “Length” of your Bench is 78”, not the width. If I’m wrong …. That’s one big Mother of a Workbench ...LOL…
The Workbench below is the one you’re speaking of. Yes?
-- I Take My Kids Everywhere! The Problem Is, They Keep Finding Their Way Back Home! (Rick, Ontario, Canada)
View NoThanks's profile
NoThanks
798 posts in 1435 days
#7 posted 01-07-2015 05:52 AM
I basically work my way around the table.
I cut the 45 on one edge first,
Then I clamp it in place with the 45’d corner lined up with the corner of the table,
I then make a pencil mark for the cut at the opposite end. Cut to the line and attach that pc.
then do the same for the 2nd and 3rd pc except I don’t attach the 3rd pc yet.
I go to the last pc that needs to be cut, line up with 45 cut end with the end of the 1st pc that was put on, mark it at the corner of the table and cut.
Then go back and attach the 3rd pc, then the last.
Never have to measure anything.
This method allows you to test the 45 cut and make any adjustments to the corner before you mark and cut the next corner.
Otherwise as stated, you just add the thickness of your wood to the length of the table.
Example for going around all 4 sides of a table.: 36” x 78” table, (using 7/8” thick wood)
36 + 7/8 + 7/8 this would be the overall length for the 2 short ends
78 + 7/8 + 7/8 this would be the overall length for the long ends
-- Because I'm gone, that's why!
View Gshepherd's profile
Gshepherd
1727 posts in 2108 days
#8 posted 01-07-2015 10:46 AM
A table like that I would just butt join it and round them babys off, you will thank me later for that one… Even the ankle biters….
-- What we do in life will Echo through Eternity........
View BinghamtonEd's profile
BinghamtonEd
2286 posts in 2276 days
#9 posted 01-07-2015 01:51 PM
I do what Iwud4u does…not measure. I get significantly better results cutting to fit, rather than measuring to cut.
View waho6o9's profile
waho6o9
8100 posts in 2483 days
#10 posted 01-07-2015 01:54 PM
“Never have to measure anything.”
Wise^
Excellent advice above as well.
View ChefHDAN's profile
ChefHDAN
1010 posts in 2756 days
#11 posted 01-07-2015 02:00 PM
Yep, slap it up alongside where it’s going and mark it, work your way around the table unless you’ve got one of those wood stretcher thingys to make the board longer when you cut it a 1/4” short
View Moron's profile
Moron
5032 posts in 3800 days
#12 posted 01-07-2015 04:29 PM
always make/purchase more crown then you think you need : )
Im not sure why anyone would put crown around the perimeter of a work bench top ?
View TheFridge's profile
TheFridge
8894 posts in 1392 days
#13 posted 01-07-2015 05:15 PM
I just measure, mark and cut it upside down using the direct measurements from whatever I’m trimming.
View Rick's profile
Rick
#14 posted 01-09-2015 03:16 AM
- Moron
He didn’t use Crown Mold. The top is 1/2” OSB covered with 3/4” MDF. Personally I would have left it at that and rounded the corner 2×4’s off a bit. Done.
What he did use looks like 1”x6” Pine which is what he wanted the 45 Degree advise for.
I would have also put the 1”x6” Apron on first and extended the 2 piece top over top of it.
Oh well. As long as Ed is happy with it, that’s the important part.
EdsCustomWoodCrafts
#15 posted 01-09-2015 05:32 PM
I thought you were calling me a moron.. My bad….if you read my post it was not crown moulding.. I agree It would look terrible…
I used 1×6 to finish the bench had some lying around and decided to use it…. moron I didn’t realize tget was your username…
I tagged it as inappropriate …. VERRY SORRY
