What do you use to coat your Saw/Power tool table surfaces?
Forum topic by Tim_CPWD posted 01-06-2015 10:31 PM 2553 views 0 times favorited 75 replies Add to Favorites Watch
View Tim_CPWD 's profile
Tim_CPWD
375 posts in 1484 days
01-06-2015 10:31 PM
Topic tags/keywords: question
From time to time the table surface for my table saw, router table and scroll saw get a bit sticky so the material doesn’t slide as easy as I would like. I have a can of Trewax paste wax that works pretty well. It is just about all gone and I will need to get something to replace it so I thought I would ask to see what others use.
-- Tim Haenisch, San Diego Ca. http://www.facebook.com/commandperformancewooddesigns
75 replies so far
View kdc68's profile
kdc68
2692 posts in 2516 days
#1 posted 01-06-2015 10:40 PM
Johnson’s Paste Wax. It’s cheap and silicone free.
v
-- Measure "at least" twice and cut once
View DIYaholic's profile
DIYaholic
19750 posts in 2914 days
#2 posted 01-06-2015 10:42 PM
Johnson paste wax, is what I use.
Any paste wax will work….
Just make sure that it doesn’t contain any silicone.
Silicone does not play nice with finishes….
EDIT: DOH!!! kdc68 beat me to it….
View WMD2006's profile
WMD2006
95 posts in 2463 days
#3 posted 01-06-2015 10:51 PM
I go with Boeshield, the spray-on stuff in white cans you can find at most home improvement stores. It makes a fairly slick surface but also keeps the moisture and rust at bay. It was critical when I had my shop set up on the FL panhandle.
-- -MDWhite
View MJCD's profile
MJCD
582 posts in 2611 days
#4 posted 01-06-2015 10:54 PM
CRC 3-36. Fine Woodworking did a review on Rust Inhibitors some years ago, and awarded this 1st place. I’ve used it for several years.
MJCD
View longgone's profile
longgone
5688 posts in 3548 days
#5 posted 01-06-2015 10:58 PM
I use Johnson wax also…been using it for many many years with excellent results
View bigblockyeti's profile
bigblockyeti
5317 posts in 1960 days
#6 posted 01-06-2015 11:00 PM
Bostik TopCote.
View JayT's profile
JayT
6010 posts in 2450 days
#7 posted 01-06-2015 11:00 PM
Another that uses good old JPW.
-- In theory, there is no difference between theory and practice. In practice, there is.
View Jim Finn's profile
Jim Finn
2688 posts in 3161 days
#8 posted 01-06-2015 11:11 PM
My benches and equipment are covered in sawdust most of the time.
-- No PHD just a DD214 Website> craftingcouple.com
24823 posts in 4090 days
#9 posted 01-06-2015 11:55 PM
I have used car polish. Seems Ok on the table saw and bandsaw
View rantingrich's profile
rantingrich
372 posts in 1585 days
#10 posted 01-07-2015 12:31 AM
When the chopped up bodies of Hookers are not littering the top of my work surfaces I use JPW as well.
LOL Just kidding
-- Rich
View AandCstyle's profile
AandCstyle
3185 posts in 2496 days
#11 posted 01-07-2015 12:39 AM
another Johnsons paste wax user here
-- Art
View TheFridge's profile
TheFridge
10818 posts in 1725 days
#12 posted 01-07-2015 12:50 AM
Johnsons here too.
Walked into my shop the other night and it looked like it rained on my saw and jointer. 0 rust.
Edit: I’m gonna guess that rich doesn’t have a sawstop to chop up his hookers.
View dawsonbob's profile
dawsonbob
3145 posts in 1995 days
#13 posted 01-07-2015 12:52 AM
And yet another Johnson’s user.
-- Mistakes are what pave the road to perfection
View alittleoff's profile
alittleoff
541 posts in 1516 days
#14 posted 01-07-2015 12:53 AM
Ive got a can of the johnson paste wax same as Kdc68 posted a picture of. When I bought my saw about a month ago I cleaned it and put a coat of the wax on. About a week ago I went to the shop to find my saw table top covered solid with rust. Since then after cleaning it up I put motot oil on the top to keep it from rusting again. My shop has no heat and it had rained for two days. There was a lot of humidity also. I don’t know if I may have buffed the wax off or maybe didn’t put enough on the top, but it was a lot of rust and I don’t want it to happen again. I also don’t want to clean the oil off it every time I use the saw. Did I not do it right, is there a trick to the Johnson wax or what. All help appreciated
Thanks Gerald
rantingrich
#15 posted 01-07-2015 12:57 AM
Johnsons here too.
Edit: I m gonna guess that rich doesn t have a sawstop to chop up his hookers.
- TheFridge
ALAS you are correct. i have to rent a tree shreader for most of my work in that area. HUMM? A new blade saw would help expedite my work
-- Rich
showing 1 through 15 of 75 replies
