13" Delta (Rockwell) Planer #22-650 Question
Forum topic by builtinabarn posted 262 days ago 1011 views 0 times favorited 5 replies Add to Favorites Watch
View builtinabarn's profile
builtinabarn
81 posts in 283 days
262 days ago
Topic tags/keywords: planer delta rockwell22-650
Quick question for any one owning this unit. I was given this planer from a friend who upgraded to a newer, bigger planer. If you are facing the planer (as if you were going to run a board through it, on the right hand side (outside of the machine), down below the planer head level, there is a box which, I think, contains the gears for the feed rollers. Well there is a turn-able rod (“T” rod or knob) that sticks out and I don’t know what it is for and I cant seem to locate a manual online. Can any one help. Thanks
-- Built in a Barn Bob
View roman's profile
roman
1125 posts in 791 days
262 days ago
It might change the feed speed and usaully by pulling out the lever or pushing the lever in changes the feed speed. Sometimes its easier if you turn the machine off and pull the drive belts so that the gears are moving when changing the feed speed.
Cheers
builtinabarn
262 days ago
The rod ,or knob, does not pull out or push in, it only spins
View KnotWright's profile
KnotWright
83 posts in 386 days
262 days ago
Here’s the manual I found for your model number, not sure if its exactly what you’re looking for, but worth a shot.
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Delta/En428-06-651-0003.pdf
-- James
View marcb's profile
marcb
705 posts in 571 days
262 days ago
Manual can be downloaded here should give you a good push in the right direction.
builtinabarn
262 days ago
Thanks. Awesome.
