Some chair repair advise please
Forum topic by RussellAP posted 01-06-2015 07:50 PM 926 views 0 times favorited 4 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
3104 posts in 2311 days
01-06-2015 07:50 PM
I’ve been supplementing my furniture business with some furniture repair. I get quite a bit just from word of mouth and CL.
Some chairs that come in have been beat up pretty badly and I was wondering what is a good glue for this kind of work. I had one last night, it’s a padded dining chair with cloth and leather seat. The seat is attached to the front legs and the back of the chair continues to the legs and is attached to the seat with angle wood which fits into the back with a kind of spline connection. They are only a millimeter deep and the customer had tried to glue it once before.
I got the splines clean, but some were in bad shape so I knew gluing wouldn’t be enough. So I used screws and dowels.
I used Titebond II and clamps which seem to work well, but tends to dry brittle and any movement can break the connection even though it’s held tight with screws and dowels.
Is there a good furniture repair glue I can use?
View Texcaster's profile
Texcaster
1285 posts in 1699 days
#1 posted 01-06-2015 10:09 PM
http://boatcraft.com.au/informationpages/epoxeglueTDS.htm
This ” Bote Cote ” epoxy is thickened with cabosil. It is gap filling, strong across the gap, can be colored with sanding dust and doesn’t run or drip. The furniture restorers here love it. I’m sure the “West System”, in the US, will have something similar.
-- Mama calls me Texcaster but my real name is Mr. Earl.
RussellAP
#2 posted 01-06-2015 10:28 PM
Thanks Texcaster, I’ll check it out.
View Rick's profile
Rick
9725 posts in 3058 days
#3 posted 01-07-2015 05:47 AM
I’ve used this many times and it holds, Tight, once it cures.
Whatever is going to be glued should be cleaned back to raw/open wood so the glue can “Wick” into the wood. Initial set is just a few minutes but should be left for 12 Hours for a full cure.
$9.95 & $13.90 at Lee Valley.
-- LIFE is what happens when you're planning on doing Other Things!
View Rick's profile
Rick
#4 posted 01-09-2015 12:33 AM
TIP:
If you find the above difficult to read Forget all that nonsense on the “Drop Down Menus” or “Tool Bar”.
Press and Hold the “Control Key” (Ctrl). While holding it down use your “Mouse Wheel” to Zoom In & Out.
You can take this Page down to 12% (About 2”) or up to 1,000%.
Rick
