Fixing slop in stub tenon/rail and stile joint
Forum topic by ADHDan posted 01-06-2015 06:56 PM 1088 views 0 times favorited 5 replies Add to Favorites Watch
View ADHDan's profile
ADHDan
800 posts in 2013 days
01-06-2015 06:56 PM
Topic tags/keywords: question
I’m making a set of flat panels (maple frames with curly maple panels) and it looks like I miscut my stub tenons in the rails – some of them have as much as 1/16” slop, but only on one side. This means that when I fit the rails and stiles together and then force the tenon to the front of the groove, the pieces mate properly. These panels aren’t going to be doors; they’re going to be used as the sides for two little cabinets that will support a desktop.
Since the tops and bottoms of the panels won’t be visible, I think my options are: (a) measure and (try to) cut a shim the exact size of each gap for each joint; (b) cut some fairly thin and shallow wedges, and wedge/glue them into the gaps during assembly (trimming off the excess after glue-up); or© clamp the rails and stiles during assembly so that I get a good glue joint on one side of the stub tenon, and hope that’s good enough.
I don’t see the last option leading to a good result, so I’m wondering whether I can get away with using shallow wedges as shims (option b) instead of cutting each shim to fit (option a). Thoughts?
-- Dan in Minneapolis, woodworking since 11/11.
5 replies so far
View bondogaposis's profile
bondogaposis
4599 posts in 2256 days
#1 posted 01-06-2015 07:18 PM
Cut some thin slightly oversize shims for the tenons and glue them in place, then trim them to fit slowly and carefully w/ a shoulder plane.
-- Bondo Gaposis
View hotbyte's profile
hotbyte
991 posts in 2880 days
#2 posted 01-06-2015 07:24 PM
Could you cut off the tenon, mortise end of rails and use loose tenon? Never seen a loose stub tenon…
4874 posts in 2398 days
#3 posted 01-06-2015 07:27 PM
I think what you want to do (B) will work just fine, but I prefer Bondo’s approach. Glue some more stock on, and trim it down.
ADHDan
#4 posted 01-06-2015 07:39 PM
Ok yeah that makes sense. I don’t have a shoulder plane (and never really use a hand plane) but I don’t see why I couldn’t just cut a bunch of thin blanks to glue to the back of each tenon, and then run that side of the tenon over a dado blade or router bit. That would get the same result as (a) without measuring each specific gap.
#5 posted 01-06-2015 07:44 PM
Indeed it would, or just use a chisel if you have one handy.
