Trouble with hand plane tear out
« back to Hand Tools forum
Forum topic by ShawnSpencer posted 01-06-2015 04:21 PM 2101 views 0 times favorited 11 replies Add to Favorites Watch
View ShawnSpencer's profile
ShawnSpencer
81 posts in 1663 days
01-06-2015 04:21 PM
Topic tags/keywords: question walnut plane
I just got a low angle jack (first hand plane) and I’m having trouble with some pretty bad tear out in some straight grain walnut. I’m sharp, taking a very light cut, have the mouth closed up to about a 32nd. I’m getting beautiful shavings. I’ve tried going both ways on the board thinking I was going against the grain. I’ve tried some googling about figuring out which way the grain is going but I’m just spinning my wheels. Any advice or links about technique, grain, just whatever would be helpful and welcome.
-- I know you know...
11 replies so far
View Mosquito's profile
Mosquito
9451 posts in 2414 days
#1 posted 01-06-2015 04:24 PM
How deep of a cut are you trying to take?
Happen to have any pictures that may help?
-- Mos - Twin Cities, MN - http://www.youtube.com/MosquitoMods - http://www.TheModsquito.com
ShawnSpencer
#2 posted 01-06-2015 04:30 PM
I joined some boards to make a panel and just trying some general smoothing and flattening. The mouth of the plane in one of the pics is wide open. I just re sharpened to be sure I was good in that area.
Mosquito
#3 posted 01-06-2015 04:33 PM
May try to retract the iron until it’s no longer cutting, and then slowly lower the iron again until it just starts to take a cut (I usually do a quarter turn on the depth adjuster, and then take a swipe with the plane, and continue until I just start to get a shaving, then advance very little from there, until I get a good thin shaving). After that, close up the mouth so it’s just a little in front of the iron (like around 1/64th” or something, not much) assuming it’s adjustable.
View JayT's profile
JayT
5825 posts in 2332 days
#4 posted 01-06-2015 04:42 PM
Are you sure you are sharp enough? That is the #1 reason why planes don’t work as expected. I’m talking “able to shave the hair cleanly off your arm in one pass with no pulling” sharp.
For grain direction, two ways to find it. Look at the edge of the board, not the face you are actually planing. Should give you some indication. Otherwise, run a hand lightly down the face of the board. It should feel smoother in one direction than the other. Plane that direction.
I generally don’t have any problem planing walnut even against the grain, so that takes you back to depth of cut and sharp as the main contributors.
View Loren's profile
10477 posts in 3769 days
#5 posted 01-06-2015 04:42 PM
Sharpen the iron so the effective cutting angle is at
lest 45 degrees. 50 will probably solve most of
your tearout problem with walnut. Problem
areas should be avoided and worked with a scraper.
ShawnSpencer
#6 posted 01-06-2015 05:44 PM
I resharpened at a steeper angle, closed up the mouth super tight, used the pet a dog technique to find the grain direction. I’m planing like I’m on tv now. Thanks for the advice everyone. I’m really loving the hand tools lately. That perfect snick of a plane is wonderful.
#7 posted 01-06-2015 05:52 PM
great. You’re on your way.
Mosquito
#8 posted 01-06-2015 06:48 PM
Excellent, glad to hear it.
View JayT's profile
JayT
#9 posted 01-06-2015 06:52 PM
Welcome to the slippery slope—the first hand plane is just a gateway drug.
#10 posted 01-06-2015 07:07 PM
When smoothing one of the reasons I prefer a
smooth plane is it’s easier to see what’s going on
when I hit a place where the grain tears. Other
than that a tuned jack works fine.
ShawnSpencer
#11 posted 01-06-2015 07:23 PM
I wanted to get a kinda do it all plane for my first. See if I liked it and what not. A nice smoother is next now. I’m really liking the looks of the bronze LN.
