Transtint dye question
Forum topic by cellar_dweller posted 03-09-2009 04:27 AM 1778 views 0 times favorited 3 replies Add to Favorites Watch
View cellar_dweller's profile
cellar_dweller
6 posts in 3618 days
03-09-2009 04:27 AM
Topic tags/keywords: transtint dye
Several of you sent a note welcoming me to LJ. Thanks for the welcome. Now on to my question. I was in need of trying to darken a stain that I was using on a new interior door. I had just purchased some Transtint dye for use on a different project and thought perhaps I could use a few drops to darken a small amount of stain. I put a little bit of stain in a plastic bowl and then added a few drops of the dye. The stain was Minwax pecan color. I was surprised to see that the transtint dye would not mix with the Minwax stain. Instead, it “beaded up” and sank to the bottom.
I have never used Transtint dye before and I am curious if anyone has an explanation for what I experienced?
-- Guy -- Swedesboro, NJ
3 replies so far
27250 posts in 4059 days
#1 posted 03-09-2009 04:43 AM
Trans tint dyes can be mixed only with water or water based and alcohol based products. The minwax stain is an oil based product. Oil and water will not mix.
View ajosephg's profile
ajosephg
1880 posts in 3798 days
#2 posted 03-09-2009 04:44 AM
Probably because the solvent in Minwax is mineral spirits and the Trnstint dye is water based.
-- Joe
cellar_dweller
#3 posted 03-09-2009 04:48 AM
Thanks for your help. I’ll keep that in mind when I go to use it in the project for which I purchased the dye.
