Dust Collection Overload
Forum topic by customturnedwork posted 01-06-2015 01:30 AM 1006 views 0 times favorited 10 replies Add to Favorites Watch
View customturnedwork's profile
customturnedwork
43 posts in 1505 days
01-06-2015 01:30 AM
Hello Everyone,
When I use my King Canada Dust Collector, after ~5 min of use the overload switch mounted on the motor trips and the DC shuts off. The motor is not hot, so it can’t be overheating. I am only using ~6ft of hose, as it is beside and directly attached to my lathe. Could it be tripping because it is drawing to many amps, because of the short hose? Or is it probably a faulty overload? The overload switch is part #45 on this diagram.
10 replies so far
View Holbs's profile
Holbs
1843 posts in 1996 days
#1 posted 01-06-2015 01:33 AM
i doubt it would be because of the short distance of hose. I can run my DC with no attachments for at least 10 mins (was gather intel on cfm intake).
-- The Carpenter Bee is derived from the Ancient Greek word wood-cutter
customturnedwork
#2 posted 01-06-2015 01:44 AM
Bill Pentz says on his website here at point 13 that a “dust collector vendor puts a warning on their dust collectors that they will burn up if run without at least 10’ of flex hose attached.” Not trying to argue for my opinion, just thinking that maybe not all DC’s are created equal.
View bbc557ci's profile
bbc557ci
595 posts in 2041 days
#3 posted 01-06-2015 01:49 AM
What’s the amp draw of the motor and what size wire feeds the outlet the DC is plugged into. Also , is the lathe plugged into the same circuit?
-- Bill, central NY...no where near the "big apple"
customturnedwork
#4 posted 01-06-2015 01:57 AM
I would have to check the above details; I think you may have misunderstood me; the overload that is tripping is on the DC motor, the lathe keeps running even when the DC has tripped.
Rick Dennington
5807 posts in 3161 days
#5 posted 01-06-2015 02:04 AM
Sounds to me like there is a bad capacitor on the motor, or is trying to go out…..Mine did the same thing once like you described, and that’s what it was….Is it throwing the breaker, or just tripping the overload switch….? I don’t have an overload swith on mine (that I know of), so if you’re not running two or three machines at the same time, and only the lathe, then it could be the capacitor…And I’m not buying that bit about using a short hose, and you have to run at least 10 ft…..They put those warnings on those machines to cover their own a$$...
customturnedwork
#6 posted 01-06-2015 02:08 AM
Only the overload on the motor is tripping…
Would the capacitator tripping cause the motor overload to trip?
Rick Dennington
#7 posted 01-06-2015 02:22 AM
Well….I’m not sure, but it’s possible…How old is the d.c.? I don’t think you said. It could be a couple of things. There could be a bad or burnt wire inside the motor housing that could be causing it to trip…just don’t know w/o getting inside the motor and taking a look….
View REO's profile
REO
928 posts in 2041 days
#8 posted 01-06-2015 02:34 AM
try it with the hose plugged and see what happens. Dc motors are not air over it wont burn out with the intake completely plugged. and take an amp reading.
4954 posts in 2460 days
#9 posted 01-06-2015 12:14 PM
I’s hard to imagine that it would be drawing too much air. The test reo suggested should give you a clue. With the inlet plugged, the fan isn’t moving any air…in effect it’s freewheeling with no load on the motor. If it trips in that condition there’s another problem semewhere.
customturnedwork
#10 posted 01-06-2015 02:35 PM
I plugged the inlet partially and it ran fine for an hour…
I guess thats my problem.The motor was quite warm though…
How hot should a DC motor be after running for 1hr?
