My Craftsman Table Saw 113 Needs A New Motor
Forum topic by deparrott posted 01-05-2015 11:21 PM 2863 views 0 times favorited 19 replies Add to Favorites Watch
View deparrott's profile
deparrott
91 posts in 2074 days
01-05-2015 11:21 PM
Up until today I would have to say I my Craftsman 10” 113 has never let me down since I bought it in about in about 1983. It’s a new day now and the guys at the motor repair shop said the motor is dead. I’m not a motor expert but something about the worn bushings that are obsolete causing it not to run. Probably a worn shaft also. My question is where to get a new motor without breaking the bank. Where should I look? Has anyone ever bought one at Tractor Supply or Harbor Freight? I see labels like compressor motor, farm duty and others but I have no idea what that really means, or if it would work for my saw. It would have to be correct physical size but maybe it’s a standard size.
Any help would be greatly appreciated. Thanks!
-- http://www.etsy.com/shop/WoodTurningCity
19 replies so far
View kdc68's profile
kdc68
2649 posts in 2244 days
#1 posted 01-05-2015 11:44 PM
Check out Grizzly…Great customer service…Give them a call to see if they have one for your Craftsman
http://www.grizzly.com/search?q=table+saw+electric+motor&s=category:Motors
-- Measure "at least" twice and cut once
View DIYaholic's profile
DIYaholic
19597 posts in 2643 days
#2 posted 01-05-2015 11:49 PM
When my C’man 113 TS motor gave up the magic smoke….
I just bought another C’man TS off of Craigslist, for a donor motor.
Much cheaper than a new motor…. That and I ended up with a larger HP motor & CI extension tables!!!
kdc68
#3 posted 01-05-2015 11:55 PM
When my C man 113 TS motor gave up the magic smoke….
I just bought another C man TS off of Craigslist, for a donor motor.
- DIYaholic
v
v
Very valid point. You may find a replacement saw in good condition and junk your current saw all together
View hotbyte's profile
hotbyte
991 posts in 2943 days
#4 posted 01-06-2015 12:04 AM
I had to replace motor on my 113 a few years back. I don’t recall model or most details but I ordered from Grizzly. The few key things I remember being sure to check for were the frame size (or type) that indicates how the motor mounts, a Totally Enclosed Fan Cooled (TEFC). I did get a motor with a few more amps (maybe 15 vs 13???). I didn’t go too much more because fear or motor weight being too much for the bracket and I have no 220V in shop.
hotbyte
#5 posted 01-06-2015 12:10 AM
Looked back in my email and I think this is the one I ended up ordering…but don’t recall paying the listed $207 price. I’m thinking it was in the $150 range.
Grizzly G2535
View Bogeyguy's profile
Bogeyguy
548 posts in 2036 days
#6 posted 01-06-2015 12:16 AM
Try Grainger.
-- Art, Pittsburgh.
deparrott
#7 posted 01-06-2015 12:20 AM
Wow, good suggestions.
I had previously thought about buying a second saw for parts. Just yesterday I would have told anyone my motor was running and sounding fine. Not sure I would trust another 30 year old motor.
DIYaholic
#8 posted 01-06-2015 12:31 AM
The donor motor came from a C’man 315 saw….
Not an older 113.
However, if you can’t find a used saw for $100.00 or less…
I would probably spring for the new motor.
View knotscott's profile
knotscott
7980 posts in 3343 days
#9 posted 01-06-2015 12:33 AM
I’d look to CL first for a donor saw. Check Ebay next.
deparrott
#10 posted 01-06-2015 12:45 AM
The donor motor came from a C man 315 saw….
Not an older 113.
I never even thought of using one from a different model. I’ll check CL and E-bay. thanks
View David_H's profile
David_H
90 posts in 1286 days
#11 posted 01-06-2015 12:52 AM
You can usually find motors on eBay at pretty decent prices. Btw what was the HP rating of the motor you had?
runswithscissors
2725 posts in 1993 days
#12 posted 01-06-2015 12:53 AM
Harbor Freight’s compressor motors can be used on a TS. The designation simply means it’s a motor capable of starting against a load (as you would have with a compressor). Those motors are all TEFC, I believe, which is a definite advantage. The farm duty one is 1750 (approx.) rpms, not so good for a TS>
You may notice that many motors come with a warning, “not for compressor use,” which means they don’t like to start against a big load.
deparrott
#13 posted 01-06-2015 02:05 AM
- David_H
The HP rating is 1.0, but I have seen some replacing those with the 1.5 for a bit more power.
deparrott
#14 posted 01-06-2015 02:08 AM
Looked back in my email and I think this is the one I ended up ordering…but don t recall paying the listed $207 price. I m thinking it was in the $150 range.
Grizzly G2535
- hotbyte
Was it this one? Click here
David_H
#15 posted 01-06-2015 03:04 AM
I replaced the 1 HP motor on my 113 motor, it was a nice improvement. If you are replacing i would go no lower than a 1.5 hp. Grizzly has one for a pretty decent price. There is also a 1.5 hp craftsman motor on eBay for a decent price right now.
One thing about the 1.5 HP motor is they come with ball bearings as opposed to the sleeve bearings in the older 1 HP motor. Makes it much easier to maintain.
