Feeding the joiner
Forum topic by bluchz posted 03-08-2009 05:05 PM 943 views 1 time favorited 5 replies Add to Favorites Watch
View bluchz's profile
bluchz
187 posts in 3370 days
03-08-2009 05:05 PM
Topic tags/keywords: question
What is the proper way to feed wood into the joiner?
-- flash=250,100]http://www.brickshelf.com/gallery/sprxtrerme/BANNERS/thornax.swf[/flash]
5 replies so far
View buffalosean's profile
buffalosean
174 posts in 3383 days
#1 posted 03-08-2009 05:25 PM
check out thewoodwhisper.com. episode 6 “the jointer’s jumpin’ will show you several good ways to flatten & joint boards.
the “getting started in woodworking” icon is a great place to start on his website
goodluck
-- There are many ways to skin a cat...... but, the butter knife is not recommended
buffalosean
#2 posted 03-08-2009 05:27 PM
sorry, I meant http://thewoodwhisperer.com
View Brad_Nailor's profile
Brad_Nailor
2539 posts in 3953 days
#3 posted 03-08-2009 06:01 PM
You want to keep pressure against the fence and on the in feed table, till you get past the middle of the board then shift the pressure twords the out feed table…basically keeping pressure on the side that has the majority of the board on it…at least thats the way I was taught! You have to remember that you are removing wood and the tables are not level.
View TomHintz's profile
TomHintz
207 posts in 3394 days
#4 posted 03-08-2009 08:30 PM
I have a story with photos and a video on using the jointer at the link below. Have faith, this machine takes a little getting used to! It looks so simple yet is very technique dependent.
Jointer Story
-- Tom Hintz, www.newwoodworker.com
bluchz
#5 posted 03-09-2009 01:00 AM
