how make sure the drill press is square to the table
Forum topic by jimmy J posted 01-05-2015 05:44 PM 2841 views 0 times favorited 10 replies Add to Favorites Watch
View jimmy J's profile
jimmy J
229 posts in 2344 days
01-05-2015 05:44 PM
anyone have a good quick way to ensure my drill press table (which is a simple homemade table) is 100% square to the drill bit? it is hard to measure against the drill.
10 replies so far
View Dallas's profile
Dallas
3599 posts in 2452 days
#1 posted 01-05-2015 05:48 PM
Put a bit in the chuck, then with a small triangle or a square resting on the base, see if it is square to the bit front to back and side to side. Poof. Done.
View Redoak49's profile
Redoak49
3196 posts in 1954 days
#2 posted 01-05-2015 07:04 PM
I do the same but have a 6 inch rod that I use as it is a bit easier than a drill bit with the spiral flutes
View Woodknack's profile
Woodknack
11478 posts in 2345 days
#3 posted 01-05-2015 07:36 PM
Another tip is bend a wire coat hanger or brazing rod into a Z shape, chuck it with the tip touching your table and turn the chuck by hand. You’ll know pretty quick if it’s really square. The Z shape magnifies any error making it easier to see.
4954 posts in 2458 days
#4 posted 01-05-2015 07:41 PM
It’s really hard to beat that z shape coat hanger trick that Rick described. It’s the one I use.
View Slemi's profile
Slemi
116 posts in 1506 days
#5 posted 01-05-2015 08:07 PM
The trick I did a few days ago. I put a drill in a machine and took some scrap wood. Drilled a little in and lifted it up. With drill still in the wood, turned the collet 180 degrees and lowered the wood to base and look for gap between wood and the base. If it is square there is no gap, otherwise there is a gap on one side, twice the error of the angle. Hope this helps. This works fo left/right error and for back/front error.
jimmy J
#6 posted 01-05-2015 08:58 PM
Rick, Slemi, both nifty techniques, which will henceforth be used in my shop. thanks.
View Charlie's profile
Charlie
1100 posts in 2251 days
#7 posted 01-05-2015 09:19 PM
scrap 1×4
drill hole through
flip it OVER (front to back, not end over end) and drill another hole from the other side.
Stick a dowel in each hole (a dowel that fits snug on the hole obviously or this won’t work at all)
Do they converge or diverge at the top?
If no, you’re square.
If yes, you’re not.
View distrbd's profile
distrbd
2252 posts in 2412 days
#8 posted 01-05-2015 10:14 PM
- Dallas
That’s how I do it,every shop has a square.the same method can be used on a bandsaw also.
-- Ken from Ontario, Canada
View tom in indy's profile
tom in indy
41 posts in 2313 days
#9 posted 01-05-2015 10:22 PM
here is another way with the “Z” wire technique from The Cap’n.
start watching at about 1.30
https://www.youtube.com/watch?v=Vq48544ps1Y
jimmy J
#10 posted 01-08-2015 04:59 PM
thanks tom
