What do you recommend?
« back to Coffee Lounge forum
Forum topic by rockman posted 03-08-2009 04:54 AM 826 views 0 times favorited 4 replies Add to Favorites Watch
View rockman's profile
3 posts in 3302 days
03-08-2009 04:54 AM
Hey fellers…and ladies. I got another one. I cut out a pair of legs for my garden bench, from a 2×8. I cut this “angeled piece” with a jig saw. Now maybe it is my cutting technique, or my jigsaw, but it is usually a pretty ugly cut because it seems as though the blade bends. I THINK that is what is happening. I was gonna get a bandsaw but someone told me I should use a scroll saw. That scroll saw seems kind of small and that tools seems more like for delicate cuts. The angeled piece is really a 25” 2×4 that angles at about 17” up. The angle is not severe, maybe tweny degrees or so. I hope I am being clear cause i’m havent mastered the “wood talk” yet. Anyway, what should I use for this cut to make as clean as possible and that wont require to much planing. Thanks guys… and ladies.
-- Rocky in San Antone
18224 posts in 3605 days
#1 posted 03-08-2009 05:11 AM
Don’t you have a table saw? If not, a circular saw with a guide clamped to the work would be better than a jig saw, I would think.
View DaleM's profile
958 posts in 3313 days
#2 posted 03-08-2009 05:39 AM
If it’s actually an angle and not a curve, then I agree that you should go with the circular saw and cut up to the point of the angle from both directions. If it’s curved and you have a bandsaw available, that would be the way to go. I’ve had the same problems with the jigsaw; it would cut at an angle even though I had it set at 90 degrees so it’s probably not your fault. I thought it would be better with my second jigsaw because it had a notched roller guide behind the blade, but my cut still angled to the side. It would usually try to follow the grain/path of least resistance especially in thicker wood.
-- Dale Manning, Carthage, NY
View dhg's profile
197 posts in 3642 days
#3 posted 03-08-2009 05:10 PM
It would have to be a circular saw with a clamped on guide or a table saw with a taper jig if the angle cut is not straight.
-- Talent on Loan from God - Rush Limbaugh
23639 posts in 3781 days
#4 posted 03-09-2009 02:04 AM
You could use the above as suggested. If you get a bandsaw you will find it has heaps of other possibilities but it depends on how much you would use it.
