"cross center" clamping jig ??
Forum topic by mjpierson posted 03-08-2009 04:44 AM 1138 views 0 times favorited 5 replies Add to Favorites Watch
View mjpierson's profile
mjpierson
86 posts in 3962 days
03-08-2009 04:44 AM
Topic tags/keywords: jig question
anyone seen or have any ideas on how best to clamp up the centers of crosses like the one in the link. I usually am able to cobble them together, but every time i swear there has got to be a better way. it is essentially four miters coming together….is there some like the picture frame jigs out there?
http://lumberjocks.com/projects/14854
-- Mike - Columbus, Ohio
5 replies so far
View DaleM's profile
DaleM
958 posts in 3353 days
#1 posted 03-08-2009 05:19 AM
Mike, I don’t know if you tried this, but you could try to rout down about 1/2 or or more into a larger piece of wood, making a cross the exact width of the cross you are making. You can then lay a piece of wax paper on top of it to keep your cross from getting glued to it, push the pieces of your glued cross in then clamp the cross from top to bottom and left to right. The routed out template will ensure the pieces line up right if the template is tight enough. Just a thought if you haven’t tried something like that yet.
-- Dale Manning, Carthage, NY
TopamaxSurvivor
18249 posts in 3645 days
#2 posted 03-08-2009 05:25 AM
Well, it would be a lot more work, but I suppose you could lap joint them, You would have to inlet the riser with the 45 angles. I’d leave them a bit slopped by a couple degrees going down into the lap joist. Then, cut the 2 cross arm pieces with their 45’s. Relieve the back side for the lap joint and leave a couple degress of relief where the pieces meet. With that little bit of angle, they should sort of be self filling in the joint like inletting a rifle stock’s metal pieces.
View John in SD's profile
John in SD
140 posts in 3782 days
#3 posted 03-08-2009 05:40 AM
Mike, Have tried using wedges to clamp it?
John
-- Life used to be soooo much simpler!!!!
View Francisco Luna's profile
Francisco Luna
943 posts in 3362 days
#4 posted 03-08-2009 05:50 AM
http://www.leevalley.com/wood/page.aspx?c=2&p=31160&cat=1,43838
-- Nature is my manifestation of God. I go to nature every day for inspiration in the day's work. I follow in building the principles which nature has used in its domain" Frank Lloyd Wright
TopamaxSurvivor
#5 posted 03-08-2009 06:57 AM
I like the splines, that would be a lot easier than inletting a lap joint. A tiny bit of relief would make the joint almost invisible if it weren’t for the change of direction on the grain.
