Mortiser as Drill Press
Forum topic by groland posted 03-06-2009 10:03 PM 828 views 0 times favorited 1 reply Add to Favorites Watch
View groland's profile
groland
183 posts in 3379 days
03-06-2009 10:03 PM
Is there any reason a hollow chisel mortiser could not be used as a drill press?
George Roland
1 reply so far
View PurpLev's profile
PurpLev
8534 posts in 3616 days
#1 posted 03-06-2009 10:10 PM
I’d say:
1. column is too close to the center of table to allow much depth for larger pieces (mortises are usually done on narrow(er) parts)
2. bit clearance to table is small – does not allow you to rotate your table away for greater height clearance under the bit
3. speed of drill is set for mortising applications, and does not have the versatility of drilling speeds.
4. cumbersome bit changing procedure (I must say that having the Jacobs toolless self-tightening chuck is priceless!)
just to name a few…
