Segmenting an ellipse
Forum topic by ken_c posted 01-04-2015 04:16 AM 1505 views 0 times favorited 11 replies Add to Favorites Watch
View ken_c's profile
323 posts in 3097 days
01-04-2015 04:16 AM
OK Lumberjocks here is a tough question, it involves segments of an ellipse. I needed to make an ellipse and I wanted to make it out of segments rather than use an entire panel of maple and my Archimedes trammel. I will use the trammel on the glue up of segments. I was hoping that there was an easy way to calculate 8 segments (2 sets of 4 identical ones). I consulted my “circular work in carpentry and joinery” book but did not find that info. Then Google, but I only found things well above my mathematical understanding. So I resorted to cad, drew it, divided it into 8 segments and measured the angles and lengths of the strait stock needed. That method works but I was hoping to just run some calculations like I do for a segmented circular turning. Has anyone out there got the info needed for the calculation task? Thanks
There are 3 angles, two segment lengths and one width as a result of cad work. in this case 17, 19, 38, 6 13/32, 4 9/16 and 3 1/4…
here is the first stage of the resulting cad work:
11 replies so far
View pjones46's profile
1001 posts in 2578 days
#1 posted 01-04-2015 07:04 AM
To calculate the perimeter of an Ellipse is very difficult as it uses an infinite sum formula. Then to cut it into a specified number of equal parts would be equally as difficult as the lengths between points equally spaced along the perimeter of the curved elliptical surface would equally difficult.
All that being said; there may be an old boat builder trick to approximate the segments which I have no clue if it exists.
-- Respectfully, Paul
View Kelly's profile
1950 posts in 2879 days
#2 posted 01-04-2015 08:15 AM
You can’t just put a circle in it and divide the 360 by eight, then mark them off on the inside and outside?
#3 posted 01-04-2015 08:46 AM
You will not get equal segments as the center of the Ellipse is not equidistant from it’s perimeter.
View AlaskaGuy's profile
3988 posts in 2244 days
#4 posted 01-04-2015 10:52 AM
Why make it harder than it needs to be? If your cad program works why not use it?
#5 posted 01-04-2015 12:50 PM
Thanks for the replies.
@kelly – the method you describe give a great octagon.
@Alaska, the reason for the mathematical quest is time and curiosity – CAD is fine and gets the job done but from making segmented rings for round turning I know the math way is faster
@PJ – it is definitely a difficult question and problem – I wish I knew a boat builder…
View hhhopks's profile
651 posts in 2312 days
#6 posted 01-04-2015 01:20 PM
Yes, you should draw it up in CAD. I think it is a lot easier. I happen to have completed a CAD exercise recently similar to your requirement.
You will able to slice it so that only two segments are needed to create the eight pieces. The segment will need to mirrored to create other parts of the ellipse. I doesn’t matter how you slice them (radially, orthgonally & segment length). The hard question really should go back to “how to draw an ellipse?”.
So that works great in CAD, but will the two patterns that you make will allow your to create the pieces with perfect fit? More likely, one or more pieces will have to be “hand” fitted to ensure that there are no gaps and maintain the smooth curves.
I would consider laying the pieces such that the gaps are uniformly spaced and have gap filled.
-- I'll be a woodworker when I grow up. HHHOPKS
#7 posted 01-04-2015 11:29 PM
I was confused as to why you need “two sets of identical ones” for your segments. I presume you are going to still be making forty-fives, rather than a mix match to end up with segments having about the same area, so requiring different angles (e.g., twenty-five degree to thirty degrees, fifty-five to sixty-five and forty-fives).
Why not just make a pattern from card board or paper (like typing sheets taped together). You’d then know about what dimension your boards need to be without producing the waste you [reasonably] were concerned with.
In the end, it shouldn’t be too far off the octagon you posted. Four boards might have to be elongated.
This all presumes you are making more of a frame than a plaque, table top or some other thingamajig.
View Dark_Lightning's profile
3115 posts in 3044 days
#8 posted 01-05-2015 01:03 AM
Another option is to use the cut out portion of the panel for another, smaller ellipse. When I make a large bowl for turning (I have one that is 14” OD, for example), I drill and use the scroll saw or a jig saw to cut out the central “waste” except for the bottom and I make another bowl from the cut out material. I’ve made as many as four bowls from one purchase of wood. Mahogany wasn’t cheap, even in 1974, when I made that particular bowl and its derivatives. I seem to be able to find only two now- the ones I gave to my parents and got back, later.
-- Random Orbital Nailer
#9 posted 01-05-2015 02:14 AM
thanks for the thoughts and responses – if I ever do it again I will use CAD again – it worked out just fine and the energy spent doing it that way was less than all the trouble I have caused posting the question.
Thanks again:
View Yonak's profile
986 posts in 1456 days
#10 posted 01-05-2015 05:09 AM
Here’s how I solved it. I had flats at the top, bottom and sides :
View realcowtown_eric's profile
608 posts in 1872 days
#11 posted 01-05-2015 05:34 AM
I;m not suprised that Hodgsons tome would’t have provided the solution, but a simple cabinetmakers elipsograph would have.
Every few years a contractor buddy calls me up and asks me if I still have mine. Borrows it to cut openings for elliptical windows
Cad don’t connect to my bandsaw anyway, but a pencil does and one heck of a lot easier and quicker
Not so hard to make
-- Real_cowtown_eric
