Got first hand plane today
« back to Hand Tools forum
Forum topic by MissouriOutdoors88 posted 01-04-2015 03:04 AM 1919 views 0 times favorited 58 replies Add to Favorites Watch
View MissouriOutdoors88's profile
MissouriOutdoors88
334 posts in 1460 days
01-04-2015 03:04 AM
I got this at a local used tool shop today for 18 bucks. Stanley No. 4. Just needed some WD-40 and elbow grease to free up the turning knob and everything else. Have it broken down and parts sitting in rust remover right now. I actually used it a little and it shaved better than I thought it would. I am looking for some advice on sharpening the blade. What kind of stone should I use? I’m pretty excited about it…looking into getting into these more in the future. Very rewarding to bring something back to life like this.
-- I'm an aspiring woodworker with a degree in Biology.
58 replies so far
MissouriOutdoors88
#1 posted 01-04-2015 03:07 AM
MissouriOutdoors88
#2 posted 01-04-2015 04:15 AM
What kind of sharpening stone and other materials do I need?
View BurlyBob's profile
BurlyBob
5899 posts in 2387 days
#3 posted 01-04-2015 04:21 AM
I am by no ways an expert with hand planes. I am a guy who was bitten by the bug a little over a year ago and now am closing on 2 dozen in my inventory. It looks to me like you’ve got a type 9 or earlier, as there’s no frog adjusting screw and yoke. I’ve got a #7 type 9 and it’s awesome. I know others will give you all sorts of advice about gear to buy for sharpening that can run into big bucks. I am pretty cheap and went with wet dry sandpaper and granite. I went to a granite countertop shop and dug thru their scrap pile. They were very happy to give me the stuff as they had to pay to haul it to the dump. I’m going back again this next week for more. I’ve got long pieces with different grits for flattening the sole and I’ve got several pieces with different grits for chisels, irons and cap levers. The only big expense was the Veritas sharpening jig. It just takes time and patience. I find it very satisfying to take a beat up rusty POS and make it work. Now that you’ve got a #4, you got to look at a 4 1/2, 5 and a 5 1/2 and a #3. The list and passion never ends. Run with it, you’ll love it.
My best,
Burly Bob
18874 posts in 1978 days
#4 posted 01-04-2015 04:23 AM
There are lots of different ways to do it. From the cheap ways like sandpaper on a piece of wood or belt sander to the expensive ways like tormek and worksharp. There’s diamond stones as well. If you google it or search on here you may find a way that works for you.
MissouriOutdoors88
#5 posted 01-04-2015 04:26 AM
I’ll do some more research on it. Any way to know how old
It is? It has a patent number on it.
View MikeUT's profile (online now)
MikeUT
172 posts in 1481 days
#6 posted 01-04-2015 04:37 AM
This is one of the better websites to check out the type and age.
http://www.hyperkitten.com/tools/stanleybenchplane/dating_flowchart.php#Types
This is another good one, it’ll help you figure out if your planes have original blades.
http://www.antique-used-tools.com/stantms.htm
View OSU55's profile
OSU55
1835 posts in 2111 days
#7 posted 01-04-2015 05:29 AM
Here’s how I hone blades: http://lumberjocks.com/OSU55/blog/39391
For primary bevel shaping I use diamond stones and/or a bench grinder. Tried various oilstones, just way too slow. You are about 3 hours away from me. Be happy to show you my plane collection and sharpening methods.
View TheFridge's profile
TheFridge
10141 posts in 1608 days
#8 posted 01-04-2015 03:59 PM
I started with sand paper and below through a crapload of it tuning a couple planes. Probably more my fault than the paper maybe, but I ended up getting some diamond stones. I have an extra coarse, coarse, fine and superfine. About 130$ -140$ for both (stones I have are double sided). I use 2000 grit paper last and then a leather strop.
View waho6o9's profile
waho6o9
8364 posts in 2699 days
#9 posted 01-04-2015 04:16 PM
congrats on your hand plane purchase!
https://www.youtube.com/watch?v=vvTcReENk9g
HTH
View poopiekat's profile
poopiekat
4371 posts in 3856 days
#10 posted 01-04-2015 04:20 PM
In the long run, you’d do well to find a proper replacement sole of the same type. For $18, you did well, but this plane has a fatal flaw. I guess nobody else wanted to tell you this.
MissouriOutdoors88
#11 posted 01-04-2015 04:56 PM
Fatal flaw in what way? I’m a little confused about your statement.
BurlyBob
#12 posted 01-04-2015 05:14 PM
Fatal flaw= busted out left side.
View bandit571's profile
bandit571
21086 posts in 2805 days
#13 posted 01-04-2015 05:14 PM
One side has had a breakout season along the way. The “flaw” would be that the sole will now flex in use, and continue to crack into two pieces.
MissouriOutdoors88
#14 posted 01-04-2015 05:55 PM
Well now I feel dumb. Rookie mistake.
View chrisstef's profile
chrisstef
17640 posts in 3128 days
#15 posted 01-04-2015 06:02 PM
The good news is that now youve got parts. Good front knob, iron, chip breaker, and frog. You should be able to score another 4 in your travels and even if its got some bad parts to it you can make it whole again. Ive bought a good bunch of parts planes myself, dont be discouraged.
showing 1 through 15 of 58 replies
