Door pivot
Forum topic by Brodan posted 01-04-2015 01:17 AM 808 views 0 times favorited 5 replies Add to Favorites Watch
View Brodan's profile
Brodan
138 posts in 1207 days
01-04-2015 01:17 AM
Topic tags/keywords: question
I want to put inset doors with leaded glass on the tv stand I’ve built. The face of the doors will be flush with the cabinet face. To access the DVD player etc the doors will swing down…pivoting on pins. Then pivot back up and held closed using a ball detent at the top. I don’t know what the hardware that the door pivots on is called so I don’t know what to search for. I want a minimum gap so a knife hinge won’t work.
I’ve sketched in what I’m thinking. A bracket with a pin screwed to the back of door, with a receiver screwed inside the casing.
I appreciate help with the name of this or suggestion of something better.
Thanks
Dan
-- Dan, TN
5 replies so far
View RussellAP's profile
RussellAP
3103 posts in 2191 days
#1 posted 01-04-2015 01:40 AM
I usually will go to a hardware specialist for this kind of thing. Look up hinges and pulls and call around till you find a place with a knowledgeable person. Usually some independent business.
View jerryminer's profile
jerryminer
888 posts in 1346 days
#2 posted 01-04-2015 02:20 AM
View kdc68's profile
kdc68
2638 posts in 2181 days
#3 posted 01-04-2015 03:12 AM
jerryminer has lead you in the right direction. Current promotion for Rockler’s is free shipping for $25.00 or more orders and today is the last day for it…...(1/3/15).....
-- Measure "at least" twice and cut once
Brodan
#4 posted 01-04-2015 03:12 AM
Yes jerryminer. That’s not what I had in mind but that certainly looks like it will do what I am looking for.
Thanks, Dan
-- Dan, TN
View NoThanks's profile
NoThanks
798 posts in 1433 days
#5 posted 01-04-2015 03:26 AM
Couldn’t you recess the knife hinges into the frame and door to get a tighter reveal?
or
http://www.rockler.com/pivot-hinges
or
http://www.rockler.com/roto-hinges-choose-size
-- Because I'm gone, that's why!
