Space between door and frame
Forum topic by Sean posted 03-06-2009 03:28 AM 5256 views 0 times favorited 3 replies Add to Favorites Watch
View Sean's profile
Sean
156 posts in 3578 days
03-06-2009 03:28 AM
Im in the midst of building a cabinet. Or rather, Im in the midst of building a door for a cabinet for our kitchen. How much separation should i set between the door and the rail of the face frame? 1/16th? Any suggestion would be appreciated.
-- "Democracy is by far the worst system of government. Except all the others that have been tried." ~ Winston Churchill
3 replies so far
View Sean's profile
Sean
#1 posted 03-06-2009 04:12 AM
oh, inset door, obviously.
View Bureaucrat's profile
Bureaucrat
18339 posts in 3614 days
#2 posted 03-06-2009 04:31 AM
I use non mortise hinges and use their thickness all around the door. If I remember right, it was 1/16”.
-- Gary D. Stoughton, WI
View Waldschrat's profile
Waldschrat
505 posts in 3398 days
#3 posted 03-06-2009 07:25 PM
The gap between door and frame is dependent on the type of hinges you are using. The more “economical” the hinges are the greater the gap will be (on the hinge side) because the hinges are not made to the precision of higher priced models, which will often have up to a 1/32 (approx 1mm) or less (1/64”) depending as I said on how much you invest, (side note, I know someone who built in high precision hinges that costed 50 euros per hinge! they were special CNC machined and everything)
So you you should check out what gap you hinges have in the close condition and then use this gap all around just like Bureaucrat said, his was good advice. Otherwise (not equal gap around door) it looks funny, at least to me.
-- Nicholas, Cabinet/Furniture Maker, Blue Hill, Maine
