Can I laminate pine boards together to make legs for a bed?
Forum topic by CXD posted 1567 days ago 3639 views 0 times favorited 7 replies Add to Favorites Watch
View CXD's profile
CXD
5 posts in 1567 days
1567 days ago
Topic tags/keywords: pine bed furniture glueing laminating kids furniture
I am new to woodworking. And, I am already in over my head. I want to make a pine bed for my 3 year old son. I want to use pine primarily because the other furniture in his room is pine, but also because it is inexpensive. Here is my problem. I cannot find any pine boards thicker than 1”. I originally wanted to use 4×4 posts for the legs, but can’t find any pine 4×4’s. Can I laminate the 1” thick boards together to “glue up” a 4×4? Will it be strong enough for a bed post? Will the glue joints hold up over time?
Any thoughts would be appreciated.
Thanks.
-- Oregon
7 replies so far
View kiwi1969's profile
kiwi1969
609 posts in 1639 days
#1 posted 1567 days ago
If your mating faces on your stock are flat, then you should have no problems at all. It,s plenty strong enough and often more stable than 4×4 stock anyway.
View gbvinc's profile
gbvinc
628 posts in 2143 days
#2 posted 1566 days ago
Sure! Plenty strong. Just make sure the glued faces are good and flat to bond well.
View Francisco Luna's profile
Francisco Luna
936 posts in 1590 days
#3 posted 1566 days ago
Sure you can, why not, make sure to use a good glue (Ultimate Titebond III -green-) and strong screw clamps.
-- Nature is my manifestation of God. I go to nature every day for inspiration in the day's work. I follow in building the principles which nature has used in its domain" Frank Lloyd Wright
View Greg3G's profile
Greg3G
815 posts in 2282 days
#4 posted 1566 days ago
Sure you can….just take a look at the furniture in some of the stores now….pine and other softwoods are used all over the place.
Keep a couple things in mind as you do this. 1st use a good quality glue and make sure you get an even layer on both mating faces. Second, use enough clamps! (You can never have enough clamps :-) And 3rd is remember it is almost impossible to keep the pieces from sliding so you will have to true up each side when the glue has dried, so have a plan for that (you can use a jointer.)
Sounds like a great project and I look forward to seeing the final photos of it.
PS….don’t worry about that feeling like you are over your head. You will soon be swimming with the rest of us.
Take care and Have Fun
-- Greg - Charles Town, WV
View Julian's profile
Julian
880 posts in 1722 days
#5 posted 1566 days ago
Another thing to add to the list of precautions is to make sure you are using wood that has a moisture content below 10%. Pine construction lumber is usually significantly more.
-- Julian, Park Forest, IL
View CXD's profile
CXD
#6 posted 1566 days ago
Thanks for all the great replies.
-CXD
-- Oregon
View kolwdwrkr's profile
kolwdwrkr
2821 posts in 1787 days
#7 posted 1566 days ago
When you clamp it up use Cauls. Pine is soft and may be dented or damaged from the clamps. Be sure to post your completed project ;-)
