Shop Vac
Forum topic by Matt posted 03-05-2009 06:02 AM 4585 views 0 times favorited 13 replies Add to Favorites Watch
View Matt 's profile
Matt
212 posts in 3652 days
03-05-2009 06:02 AM
Hows everyone doing? I’m looking for a shop vac to use as a dust collection for my garage. I have very and I mean VERY little room in my garage, (10 foot wall with a bench that extends almost two feet) So a dust collection is out of the question, plus money being so tight. I need one somewhat fast also cause my father is tired of having sawdust everywhere.
I was looking at this one. http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&langId=-1&catalogId=10053&productId=100592175&N=10000003+90401+524498+1600 But it looks a little cheap to me. I want to spend around 50 to 100 dollars on a vac also. I’m completely dumb when it comes to vacs, can anyone point me in the right direction? I kinda want a hose thats 2.5D also so I can connect it to dust ports.
Thanks guys!
-- Hold on! Let me get the board stretcher!
13 replies so far
View PurpLev's profile
PurpLev
8534 posts in 3551 days
#1 posted 03-05-2009 07:30 AM
I’d go with the 16 Gallon 6.5HP models – larger capacity = less times to empty the vac, higher HP = better suction (especially important if you want to use longer hoses or duct work). on top of the shop vac itself, I’d recommend getting a HEPA filter for it – for your health and safety, and also filter bags – these will do 2 things: one – they’ll make it easier for you to empty the vac – you simply take the filter bag out , and trash it with everything in it, while not having to spread the dust back in the air, and two – it’ll prolong and protect your HEPA filter.
you’re on the right track ;) keep going
View Dadoo's profile
Dadoo
1789 posts in 3893 days
#2 posted 03-05-2009 10:50 AM
Ditto with PurpLev. That Rigid you’re looking at only develops 2.5HP…very weak. Go to Sears and get yourself a craftsman 6.5HP with 16 gallon capacity. The Craftsman also converts to a 170mph leaf blower which is great for getting those cobwebs on the ceiling! Besides, the Craftsman is easy to get supplies for too!
View Rob1's profile
Rob1
26 posts in 3301 days
#3 posted 03-05-2009 02:53 PM
I too suffer from a small garage shop. Look into this unit 5 Hp, wall mounted, long hose, add a dust deputy and you are in business. $99
http://www.ridgid.com/Tools/WD5500-Wall-Vac/index.html
I recommend the dust deputy, and a clean stream filter for the vac.
-- Regards, Rob
View tenontim's profile
tenontim
2131 posts in 3647 days
#4 posted 03-05-2009 03:06 PM
I have a 5 gallon ShopVac, hooked up to a Dust Deputy, that I use for collecting sanding dust and general clean up. The ShopVac’s aren’t any better made than the rest, but the customer service is great. Mine had a motor go out, and when I called about replacement cost, they told me their motors don’t burn out, and sent me a free motor.
View Pie's profile
Pie
187 posts in 3308 days
#5 posted 03-05-2009 03:11 PM
I bought this one and it works well. I built my own dust collectorfrom a metal trashcan ($19) I bought at Lowes. Here are the plans for it and it works well. I have even seen the same DC without the bottom round piece (check out this link and youwill see what I am talking about.) and it seems to be working well.
http://www.cgallery.com/jpthien/cy.htm
So for under $150 or maybe less you can have a decent DC. You can build a cabinet out of a few 2×4’s and stack the vac over the dc like I did.
Hope this helps.
-- Pie
View Woodchuck1957's profile
Woodchuck1957
944 posts in 3667 days
#6 posted 03-05-2009 03:59 PM
Useing a vacuum for dust collection on a table saw, jointer, surface planer, etc. is like useing a hand saw to cut a large tree down. You can probably find a used 1 hp dust collector ( with a little patience ) for around $100 and be alot better off.
View brianinpa's profile
brianinpa
1812 posts in 3626 days
#7 posted 03-05-2009 07:03 PM
Woodchuck, I have to somewhat disagree. I use my shop vac for all of my dust collection in my garage shop. I intend to purchase a full blown dust collecting system, but I won’t do it at this time. I know a vacuum in not the best thing to use, but to liken it to cutting down a tree with a handsaw is a bit excessive. The only true down size of using a shop vac as your dust collection system would be that you can only use it on one tool at a time, and if the tool is equipped correctly, a shop vac provides sufficient suction to collect all the dust the tool can make.
Woodchuck1957
#8 posted 03-05-2009 07:22 PM
Brian, most of us are one man shops and thats about all we can use is one machine at a time. I understand that people can’t afford everything, I certainly can’t either, but I wouldn’t say that a shop vac is equal to a dust collector, the CFM isn’t there, and also a larger hose means less clogs. I’ll admit that in my smaller shop in the basement I have a fairly large older Craftsman vacuum hooked up to a Contractor’s saw that I have designed dust collection for, it works fairly well with the vacuum, but I know it’s not the ideal setup like I have out in the main shop / double car garage with basically the same saw setup and a dust collector. I wish I had a video cam, I’d clear this up in a heartbeat.
View Pie's profile
Pie
#9 posted 03-05-2009 08:20 PM
I have a small shop, 12×16 or so and I have a shop vac and homemade DC. Before that, I had nada with sawdust, chips etc all over everything and inside my lungs as well I am sure. Now when I look at my small shop after cutting I have about 99% less sawdust etc. I wouldn’t try and compare my DC to one you can purchase for a lot more $$$ because what I have works really well.
Buuuuut, if I had a larger shop and was making some $$$$ with my hobby I am sure I would have gone with a DC that can handle the amount of sawdust etc and can pull in more air cuz my ducting would be longer etc… and yes I would have eith 4” – 6” ducting instead of a single 2.5” hose, although I can now use 2 hoses at a time.
Anyway, it is hard to compare something that cost $$$$ and is machine made and engineered way better than a shop vac with a home built DC. I haven’t used my DC on my planer yet but I plan to and will see how well it works.
-- Pie
View juniorjock's profile
juniorjock
1930 posts in 3668 days
#10 posted 03-06-2009 12:28 AM
Well…... I have to agree with Woodchuck1957….. and everyone else. Anything is better than nothing when it comes to your lungs. So do what you can now and when you can, get a better DC. The Shop Vac is better than letting the chips fly out everywhere but I just don’t think it will be able to keep up with a planer.
- JJ
View Walt's profile
Walt
245 posts in 2741 days
#11 posted 10-08-2010 02:56 PM
Matt
Check Sears Holiday 2010 catalog Page 234 Is a Sheppach shop vac that come with adaptors for all types of wood working tool. The sale price is $99.00. The only thing I would do to it is put it on a wheeled base so you could move it from tool to tool.
I should store under a workbench without any problem
-- Walt Wilmington Delaware, http://waltlumley@yahoo.com
View TheWoodNerd's profile
TheWoodNerd
291 posts in 3094 days
#12 posted 10-08-2010 10:08 PM
Well, that’s not really true. The thing that damages the lungs is the super-fine particles. A shop vac probably doesn’t generate enough airflow to capture this stuff. So it’s probably the same as nothing, from that perspective.
If you did get enough airflow, however, a shop vac just spews this material right back into the air. In that case, a shop vac might be worse for your lungs. You can get a HEPA filter, but I’m guessing it would clog so quickly it would be a real pain.
Now, in terms of keeping things clean, yeah, that’s a good thing. I had to restrict my stepson from using my shop anymore because of (among other things) his chronic inability to clean up after himself.
-- The Wood Nerd -- http://www.thewoodnerd.com
View Walt's profile
Walt
#13 posted 10-09-2010 04:08 AM
Shop vac or a complete ducted system you need a respirator to complete the protection. That cost less than 40.00 and is cheap protection
