Making a dado without a tablesaw or router
Forum topic by daddywoofdawg posted 01-02-2015 05:50 PM 857 views 0 times favorited 6 replies Add to Favorites Watch
View daddywoofdawg's profile
daddywoofdawg
1028 posts in 1444 days
01-02-2015 05:50 PM
Topic tags/keywords: milling joining
I need to make a swallow dado in plywood and I don’t have a table saw or router or plough pane.How can I go about it?I do have a demel and straight bit,skil saw,chisels.
View johnstoneb's profile
johnstoneb
2690 posts in 2042 days
#1 posted 01-02-2015 05:54 PM
You could clamp a straight edge to the wood and run the saw next to it, move it over a kerf width at a time until you get the width needed then use the chisel to clean up the dado.
-- Bruce, Boise, ID
View Loren's profile
9752 posts in 3517 days
#2 posted 01-02-2015 06:29 PM
what Bruce said.
A dado can also be cut using a back saw to define the
sides. There were long back saws available to do this.
I had one with perhaps a 20” long saw blade… not sure
if I still have it. Then the middle waste is chiseled out.
View WhyMe's profile
WhyMe
934 posts in 1430 days
#3 posted 01-02-2015 09:55 PM
Sounds to me that you need to go out and buy a router. They aren’t that expensive. The skillsaw is your best bet doing multiple cuts until you get the width you need.
daddywoofdawg
#4 posted 01-02-2015 11:37 PM
ya router is on the list,got a bandsaw for xmas instead
View Dallas's profile
Dallas
3599 posts in 2356 days
#5 posted 01-02-2015 11:46 PM
Make a Hags Tooth out of an old allen wrench.
View Moron's profile
Moron
5032 posts in 3762 days
#6 posted 01-03-2015 12:23 AM
why not just butt joint it
couple of brads
a few screws
