Square Drive Screws
Forum topic by interpim posted 03-04-2009 06:43 AM 6352 views 1 time favorited 49 replies Add to Favorites Watch
View interpim's profile
interpim
1170 posts in 3363 days
03-04-2009 06:43 AM
Well, I am fed up with stripping out philips driver bits, so I have decided I want to use square drive screws from now on. I have done a bit of shopping online, and quickly realised that there are way to many different types of screws out there LOL…
I found this site http://www.mcfeelys.com/flat-head-screws/3 and they seem to have some fairly good deals. Does anyone have any experience with this site, and can say if these are good deals or not?
Also, does anyone recommend a certain brand/type of screw for general purpose assembly? I find myself using 1 1/4” screws most of the time…
-- San Diego, CA
49 replies so far
View MedicKen's profile
MedicKen
1610 posts in 3367 days
#1 posted 03-04-2009 07:16 AM
I have known about McFeelys for a few years. I have only purchased from them once and I am happy with what I received. I was putting some 3/4 MDF shelves together and bought the confirmat type screws and drill. I must say I am pleased with the purchase, I have not had any other type of fastener hold as well. Even without glue the joint is much stronger. As for the rest of their products if they are anything like what I have already purchased they will be good. I will buy from them again!
Douglas Bordner
4021 posts in 3968 days
#2 posted 03-04-2009 07:29 AM
I love McFeeley’s. Plenty of information in the catalogs that will help you get the right screw for the job. They occasionally have some good deals on tools too.
View oldskoolmodder's profile
oldskoolmodder
801 posts in 3585 days
#3 posted 03-04-2009 07:39 AM
Square drive is the way to go, BUT, Get a good quality driver bit, not the cheap ones that are out today. Also, McFeely’s claims to be the best or originator, or some such stuff, but their prices are higher than you can get locally in most cases.
I’ve been connecting almost everything with pocket screws lately, and try to use the Kreg brand as they are cheap, and hold really well, but there are other brands out there, such as what is at McFeely’s. When building a deck I only use the square drive screws which I believe are available in 1 1/4”, (but could be mistaken). I know for sure that Rockler has 1 1/4” square drive (non deck) screws available, VERY cheap.
View tooldad's profile
tooldad
660 posts in 3620 days
#4 posted 03-04-2009 07:39 AM
If you have a fastenal store in your area, they are a good resource, especially if you like to buy in bulk
View doyoulikegumwood's profile
doyoulikegumwood
384 posts in 3897 days
#5 posted 03-04-2009 08:06 AM
i have to agree with tool dad McFeelys is good but more pricey then fastenal i go thru 1” and 1/4 screws by the ton and get them from fasenal they even have the self tappers you need for pocket screws.
-- I buy tools so i can make more money,so ican buy more tools so I can work more, to make more money, so I can buy more tool, so I can work more
TopamaxSurvivor
18193 posts in 3581 days
#6 posted 03-04-2009 08:39 AM
I’ve run a cagillion sq drive screws in the umteen years. Only way to go, but the drivers do eventually wear out too. As soon as they don’t hold srtaight, throw them away!
View cmaeda's profile
cmaeda
205 posts in 3459 days
#7 posted 03-04-2009 08:49 AM
I use to strip screw heads a lot too and I still do sometimes but I found three things that really improved my screw driving abilities. First is the bit. Make sure you get a quality bit. I use Dewalt bits. When the bit starts slipping while driving the screws, toss it and chuck a new bit. Second is to make sure you use the correct size bits. There are two common sizes for phillips screws so make sure you’re using the correct size. The last thing is to put pressure on the bit while you are turning the screw.
View Dadoo's profile
Dadoo
1789 posts in 3895 days
#8 posted 03-04-2009 12:37 PM
I myself prefer square drive. I’ve also seen some new deck screws that use a Torx bit…jury is still out on that one.
View NY_Rocking_Chairs's profile
NY_Rocking_Chairs
508 posts in 3502 days
#9 posted 03-04-2009 12:47 PM
I buy the coated decking screws from HD. These use a combination square/phillips head and each box comes with the bit. I have never had one strip on me and they will last just about as long as SS.
I have tried cheaper versions of these screws and just about every one stripped on me, I took those back and got my $$$ back.
I have purchased SS screws from McFeely’s, but the coated deck screws are readily available at the end of the road, and the total cost is still less than buying 10 lbs from McF and getting them shipped.
-- Rich, anybody want a peanut?
View Todd Thomas 's profile
Todd Thomas
4969 posts in 3353 days
#10 posted 03-04-2009 01:19 PM
I have been using the screws I can get here at HD….I did have this same problem with the philips head screws what help it for me was a switch in tools…I always use a cordless drill to drive screws…until I got an impact driver…it helped/solved most of my stripped screw head issues….....
-- Todd, Oak Ridge, TN, Hello my name is Todd and I'm a Toolholic, I bought my last tool 10 days, no 4 days, oh heck I bought a tool on the way here! †
View Boardman's profile
Boardman
157 posts in 3666 days
#11 posted 03-04-2009 04:58 PM
Square drives make it sooo much easier, but you can easily drive the suckers so far you can split the wood, so you have to develop a new “feel” for driving them. But you’ll never go back to phillips.
They come in both fine and coarse threads. I like the coarse threads but they are easier to drive too far. Kreg, for instance, recommends fine thread for hardwoods, and coarse for softwood.
View Kindlingmaker's profile
Kindlingmaker
2656 posts in 3431 days
#12 posted 03-04-2009 05:09 PM
McFreelys has an assortment of srews, mostly leftovers from their shipping department that is on sale right now and its $15 for a mixed 5 lb box and that includes shipping. Just call and tell them you want their special.
View skydog's profile
skydog
11 posts in 3530 days
#13 posted 03-04-2009 05:11 PM
I went through the same transition to square drive about a year ago and am quite happy I did. I usually get them from McFeeleys, and now have a large assortment at the ready. It does represent somewhat of an investment, but sure beats running to HD every time you need a new size. Also, there was an article in one of the mags a few months ago (Popular Woodworking?) that showed the performance of the standard McFeelys screw to equal the more expensive Spax…
View stanley2's profile
stanley2
340 posts in 3700 days
#14 posted 03-04-2009 05:50 PM
Too hard to resist commenting – Canadian P. L. Robertson received his patent for the square headed screw in 1909. Yes, 100 years ago. It is so far superior to the slot or the Philips headed screws it is amazing to me that it has not been universally adopted as the primary screw. Our son lives in Dallas and when we were doing some home improvements we had to rely on HD for these screws since they were not readily available in local hardware stores. You can easily drive a 3 inch deck screw or a #5 – 1/2” hinge screw w/o slipping and marring the work area.
-- Phil in British Columbia
View Brad_Nailor's profile
Brad_Nailor
2539 posts in 3862 days
#15 posted 03-04-2009 08:46 PM
Square drive, or Robertson screws are the only way to go. They allow more driving force with less rotational torque effects forcing the drive bit out of the screw head. I got turned on to them working at a cabinet shop (thats all we used). We bought them in huge quantities ,and they also had a special “drill” tip and countersink ribs under the screw head, but I found that if you used a countersink bit then the ribs would dig the screw in deeper than you wanted it to go. So when I buy them for myself I buy the ones without the countersink helpers…they tend to tighten better when assembling things like casework.
showing 1 through 15 of 49 replies
