Forum topic by Gatorjim | posted 01-02-2015 12:16 AM | 1433 views | 0 times favorited | 20 replies | ![]() |
Hi every one. I am making real large spice cabinet for my wife it will attach to the side of a pantry style cabinet in the kitchen. As you can see in the pictures I will post I used a piece of pegboard as my pattern for the shelf pegs. I used a brad point bit with a stop collar and you can see almost every hole had some tear out. Why did this happen and what can I do to not have it happen again. I am cleaning them up with a exacto knife and its inside the cabinet so its not a big deal but it might be on a future project. Oh and it’s 3/4 plywood.
-- My theroy in wood working will be. If I'm not enjoying doing it i won't do it. |
20 replies so far
#1 posted 01-02-2015 12:26 AM |
My initial thought is that the spurs on the brad point bit are dull. Rather than slicing cleanly through the veneered plywood they are tearing through as the bit spins….. -- Measure "at least" twice and cut once |
#2 posted 01-02-2015 12:29 AM |
Is that the entry hole? If so I would say you need a better drill bit. Even my budget brads leave a pretty clean entry hole compared to that. -- If someone tells you you have enough tools and don't need any more, stop talking to them, you don't need that kind of negativity in your life. |
#3 posted 01-02-2015 12:30 AM |
The tips on the bit were dull, or that looks more that blowout on the bottom. If you’re unsure next time, use a forester bit, or use a brand new brad point- in fact, in that application, get a few new brad points, that is a lot of holes. other thoughts, horrible runout in the chuck, the bit not being square to the surface when engaged, speed on 2 RPM….. not sure hat else. No wait, it just hit me. You had the slicing tips in the wood then hit the button on on your drill. You need to have only the bit tip engaged, have the bit going full speed then plunge. yep, thats it. its a technique issue, the hand drill is a tough to get good results in that application. You need a drill press for this, no doubt about it. |
#4 posted 01-02-2015 12:31 AM |
GatorJim, are those “entry” holes or “exit” holes? -- ....And on the seventh day the Lord created the Les Paul...and it was good. |
#5 posted 01-02-2015 12:36 AM |
v v From the photos, the holes don’t go all the way through, so they are entry holes -- Measure "at least" twice and cut once |
#6 posted 01-02-2015 12:53 AM |
You need a better quality drill bit. |
#7 posted 01-02-2015 01:11 AM |
Go in with the bit until just the pilot spur breaks through, then use that hole as a guide to come in from the other side and drill until you complete the hole. -- Eric, central Florida / Utor praemia operibus duris |
#8 posted 01-02-2015 01:16 AM |
Wouldn’t that just screw up the other side? -- ....And on the seventh day the Lord created the Les Paul...and it was good. |
#9 posted 01-02-2015 01:22 AM |
v v The holes aren’t all the way through. He has a stop collar on the bit and the photos show they don’t -- Measure "at least" twice and cut once |
#10 posted 01-02-2015 01:25 AM |
I had the same kind of problem with a new bit used in pine, . I was using a Rockler shelf pin guide and I may have hit the wood before it was up to speed. if you get this figured out let me know -- "The pursuit of perfection often yields excellence" |
#11 posted 01-02-2015 01:39 AM |
Some of the vets out there correct me if I’m wrong, but shouldn’t that bit be going FULL speed when it contacts the wood? -- ....And on the seventh day the Lord created the Les Paul...and it was good. |
#12 posted 01-02-2015 01:53 AM |
I dislike the chip clearing abilities of 1/4” forstners, but they do make a clean entry hole. I also assumed those were blowout on exit, but I now see they are not through holes. -- I admit to being an adrenaline junky; fortunately, I'm very easily frightened |
#13 posted 01-02-2015 08:46 AM |
Winner I bet. What you can do is put a piece of waste wood, like 1/8 ply, between the pegboard and cabinet so the drill will be full speed when it hits the good wood. -- Rick M, http://thewoodknack.blogspot.com/ |
#14 posted 01-02-2015 03:14 PM |
sacrificial board on bottom and top, drill both sides at the same time…........ gone easy fix for what I see, just run it through the thickness planer and gonzo goes the blowout -- "Good artists borrow, great artists steal”…..Picasso |
#15 posted 01-02-2015 06:46 PM |
NO NO NO, this is in plywood. You wouldn’t run that through a planer. -- Check out my projects and videos http://dlgwoodwork.com |
Forum | Topics |
Woodworking Skill Share
12029 |
Woodturning
2108 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4904 |
6695 |
28059 |
CNC Woodworking
212 |
Hand Tools
5410 |
Jigs & Fixtures
1419 |
Wood & Lumber
6232 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4757 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8845 |
