Spindle turning
« back to Woodturning forum
Forum topic by MrRon posted 01-01-2015 05:22 PM 1073 views 0 times favorited 6 replies Add to Favorites Watch
View MrRon's profile
MrRon
4627 posts in 3145 days
01-01-2015 05:22 PM
Topic tags/keywords: question lathe turning
I would like to make some spindles for a baby crib. I am going to use Poplar dowels. I don’t have a lathe duplicator, so is there a way I can turn about 25 spindles and have them all come out the same? Also does anyone know how to put a tenon on each end of each spindle, all the same? I probably will need a jig to do it. I know I can buy spindles, but they would add to the cost considerably.
Is Poplar good enough for making clean spindles or is there a better wood I should use?
View DaleM's profile
DaleM
958 posts in 3286 days
#1 posted 01-01-2015 05:33 PM
Make a story stick with all your measurements on it and have calipers ready. Several calipers work better so you don’t have to keep adjusting. I just do the tenon the same as anything else. Just get it close with a gouge and then finish it off with a skew chisel to flatten it out. You can even use a wrench as your caliper; just match it to your drill bit for the mortise. Here’s a good article that shows a good story stick. http://www.craftsy.com/blog/?p=133757&ext=FB_WWC_LP_Blog_blog8_2014-12-27&utm_source=Facebook&utm_medium=Social%20Engagement&utm_campaign=Woodworking%20Club-Registrations&initialPage=true
-- Dale Manning, Carthage, NY
View dannelson's profile
dannelson
188 posts in 2273 days
#2 posted 01-01-2015 05:44 PM
put an indexer on your cnc and push play
-- nelson woodcrafters
View TheDane's profile
TheDane
5364 posts in 3565 days
#3 posted 01-01-2015 06:26 PM
I made a set of tenon-making tools. I bought a set of open-end wrenches at Harbor Freight, and ground the short side of the wrench to create a sharp cutting edge.
Turn the blank to round and a bit over size, then put the wrench (long side down) under the blank and push in. I get a perfectly sized tenon every time.
Unless you have specific finishing requirements, poplar would be the correct choice, It is stable, turns well, and takes paint well.
MrRon
#4 posted 01-01-2015 11:25 PM
Make a story stick with all your measurements on it and have calipers ready. Several calipers work better so you don t have to keep adjusting. I just do the tenon the same as anything else. Just get it close with a gouge and then finish it off with a skew chisel to flatten it out. You can even use a wrench as your caliper; just match it to your drill bit for the mortise. Here s a good article that shows a good story stick. http://www.craftsy.com/blog/?p=133757&ext=FB_WWC_LP_Blog_blog8_2014-12-27&utm_source=Facebook&utm_medium=Social%20Engagement&utm_campaign=Woodworking%20Club-Registrations&initialPage=true
Thanks for the link. The wrench is a good idea.
- DaleM
View Rick_M's profile
Rick_M
11079 posts in 2282 days
#5 posted 01-02-2015 08:34 AM
View lew's profile
lew
11939 posts in 3657 days
#6 posted 01-02-2015 04:04 PM
Gerry is right on with the spindle “caliper”. You can use just the open end wrench as is until you get a spare set to modify. I usually make a full size drawing of the turning with the transitions marked, then position the drawing (story stick) close to the turned piece
