Grizzly 6" Jointers
Forum topic by Xrayguy posted 03-02-2009 11:07 PM 730 views 0 times favorited 1 reply Add to Favorites Watch
View Xrayguy's profile
Xrayguy
39 posts in 3417 days
03-02-2009 11:07 PM
Im getting ready to order a grizzly 6” jointer, im trying to figure out which one would be the best for ease of use and changing blades. I like the spiral cutter head versions but i havent found to much information about them, what is the difference between the two kinds. I dont really plan on using to much figured woods. Is it a smoother cut with the blades? easier to change the spiral cutter heads? please help:)
-- Brad J
1 reply so far
View cabinetmaster's profile
cabinetmaster
10874 posts in 3558 days
#1 posted 03-02-2009 11:15 PM
I have a grizzly with the standard cutter head. The planer we use at our shop where I work has the spiral head. We usually change the blades on it once a year. The blades on the spiral cutter have 4 edges to work with. When the planer starts getting dull, you just rotate the blades a quarter turn. After rotating a 4th time, you throw them away and buy a new set. I like them both but it seems the spiral does a somewhat smoother finish.
