Shop Vac Question
Forum topic by CharlieM1958 posted 271 days ago 825 views 0 times favorited 21 replies Add to Favorites Watch
7675 posts in 1117 days
271 days ago
This may be a dumb question, but I honestly don’t know the answer…. physics was not my best subject.
After reading some positive comments, I have ordered a Dust Deputy to hook up to my shop vac. I know it’s not a dust collection system…. I am mainly getting it because I’m tired of constantly clogging up the filter with fine dust when I clean up in the shop.
Here is the question: Does length of hose have any effect on suction? I was thinking about getting a long hose (maybe 20’) so I can pretty much leave the vac stationary while I just drag the hose around as I clean up. I also use the shop vac for my router table and spindle sander dust ports. But I don’t want to order a hose only to find out suction is diminished.
Any of you guys or gals have first hand experience with this? Thanks!
25811 posts in 1299 days
271 days ago
Charlie: The amount of vac might be deminished but it makes your labor easier. I hook up a couple of flex hoses from a couple of shop vacs and go around the shop. It’s easier than dragging the vac around after me and then moving it to get the dust under it.
271 days ago
Thanks, Karson. Yeah…I’m tired of doing that dance. Plus, even though it is on wheels, it always gets hung up on something as I’m trying to drag it around.
View PurpLev's profile
PurpLev
2764 posts in 547 days
271 days ago
It will reduce suction, but it might not be that much that it’ll bother you (depending on length of hose, and your ShopVac’s HP), knowing the hose lengths that are available on the market – I assume it’ll be just fine for your needs. as long as you’re not trying to get a 50’hose that is ;)
3055 posts in 920 days
271 days ago
Charlie:
If you can put in a length of 2” vac piping with a couple or three takoffs you should be golden for most of your needs.
I used a similar setup before I installed central vacuum.
Worked just fine considering the size of the system.
View jeh412's profile
jeh412
131 posts in 274 days
271 days ago
I often use an extra hose (or two) just so I don’t have to constantly untangle the vac. Any loss of suction isn’t noticeable with my vac, although there probably is some. My vac is a Ridgid WD1250, which is pretty powerful. I don’t think my old Craftsman vac would have done well with an extra length of hose.
-- John, co-owner Sawdust 'n Stitches
271 days ago
Thanks, guys.
For the record I have a 16 gal. Craftsman like this one.
jeh412
271 days ago
You should be OK, Charlie. My understanding is that the same company that makes Ridgid vacs also makes the newer Craftsman and that many parts are interchangeable, so you should have plenty of power.
View Kindlingmaker's profile
Kindlingmaker
1477 posts in 425 days
271 days ago
Charlie, we have the same vac and its a beast. The vac is cumbersome to say the least and it gets clogged up on each use BUT it does suck! An extra length of hose will work just fine. I will be replacing my STIFF hose with a much more flexable one and will be putting a prefilter on somehow. Woman’s nylon hose works well but that too gets clogged very easy. All this clogging does mean that the vac and the filters are working well. (Just a pain in the bottom.)
Craftsman on the lake
819 posts in 336 days
271 days ago
That’s my shop vac. Hey, if you’re going to leave it in one place and want a long flexible pipe I have an fairly inexpensive solution that I use for short extensions to me stationary tools from my 4” dust collection system and on my shop vac.
Walmart sells RV sewer hose. It’s ribbed black stuff like our shop vac but much, much more flexible. It’s 3” so some reducing will be necessary. The best news is that it’s about $7 for 20 feet of it. And it is tough and won’t collapse. After all think about what it was ment to carry.
-- The smell of wood, coffee in the cup, the wife let's me do my thing, the lake is peaceful. http://web.me.com/deceiver6/Deceiver/Craftsman_on_the_lake/Craftsman_on_the_lake.html
271 days ago
Hmmm… thanks for the tip, Daniel.
Sounds like my idea will work out. I knew this was the place to ask!
View TheDane's profile
TheDane
209 posts in 562 days
271 days ago
I have a 5.0hp ShopVac that I use with 20’ of hose and one of Rockler’s Mini Dust Collection Separators (the one that fits a 5-gallon bucket).
I haven’t noticed any loss of suction, most everything winds up in the bucket, and the ShopVac’s filter doesn’t clog up. Makes life a lot simpler.
The Dust Deputy is probably an even better solution.
-- The only place success comes before work is in the dictionary. -- Vincent T. Lombardi
View Chris Davis's profile
Chris Davis
558 posts in 881 days
271 days ago
I was gong to suggest a pool vac hose, but Daniel’s idea sounds better (cheaper)
-- Watch live video from our shop. http://wwbeds.com/live.htm
271 days ago
Chris, thanks for the idea. I have a nice long lenth of pool hose coiled up next to the house. I rarely use it because I have a Polaris automatic pool cleaner. It never crossed my mind to try that.. It’s a little on the heavy side, but I might give it a try.
View rtb's profile
rtb
681 posts in 612 days
271 days ago
Charlie, i have the 16 gal rigid and routinely use with 2 hoses. not really a problem. The only tool that it connects to is my ROS and if suction is reduced it would be hard to prove ( and rigid make its hoses extra long to start with)
View skeezics's profile
skeezics
199 posts in 618 days
271 days ago
I do it differently….. open up the doors and fire up the leaf blower! :-]>
-- hey honey! watch this!
View poopiekat's profile
poopiekat
220 posts in 633 days
271 days ago
Hey Charlie! Daniel is right about RV sewer hose. After buying your hose at WalMart, go to an RV dealer parts department and check out the cool collection of male/ female twist-lock connectors that you can use on your machines. There are flush-mount tank fittings(no pun intended) and other flanged fittings with which you can standardize your whole shop to a 3” RV system!!
-- If Stradivarius was alive today, he'd be using Gorilla Glue.
View woodbutcher's profile
woodbutcher
432 posts in 1065 days
271 days ago
CharlieM1958,
I wanted to chirp in and help all I could! As long as hoses are still ‘Round’ and you haven’t tried to ‘Square’ them up by stepping on them like I have-adding another probably wont hurt! But know how you like to keep things ‘Square so I just don’t know!-LOL-Take care my friend.
Sincerely,
Ken McGinnis
-- woodbutcher north carolina
View woodsmithshop's profile
woodsmithshop
291 posts in 444 days
271 days ago
you guys clean your shops?
-- Smitty!!!
271 days ago
After a project I enjoy cleaning and believe me I don’t normally like doing that. I begin by running around and putting away all the stray tools then I use my compressor to blow dust off all the tools, walls, and such then sweep and then vacuum. See, even a slob has a system.
View Tom Adamski's profile
Tom Adamski
309 posts in 670 days
271 days ago
Charlie,
Using a Shop-Vac to clean up the shop sucks… no pun intended. As you know the filter clogs up so fast and cleaning it all the time is no fun. Instead of going the way of the seperate dust collector, (knocking it over and dealing with vaccume leaks), I opted to try filter bags. They work very well. The bag keeps the filter from getting clogged.
Tom
-- Anybody can become a woodworker, but only a Craftsman can hide his mistakes.
View mmh's profile
mmh
1410 posts in 621 days
271 days ago
We have a total of 4 shop vacs: One 4.5 hp, One 3.5 hp, one 2.5hp and one 1.5 hp. They are tucked under the workbenches and the large ones can be wheeled out to get to the areas that need cleaning. The longer the hose, the less suction, so the inconvenience of having multiple vacs has worked better than the longer hose. If you get a smaller diameter hose, the suction will be better, but then you may have clogging if the chips or shavings are too large. Cleaning them takes 5-10 minutes outside at the compost pile. I found a stiff bristle bottle type brush that bends that may have been designed to clean the paper filters at HF for $4. This seems to work fine as it doesn’t damage the paper pleats of the filter.
