Making your own Sanding Belts?
Forum topic by BigFoot Products Canada posted 03-02-2009 10:31 AM 12994 views 0 times favorited 11 replies Add to Favorites Watch
View BigFoot Products Canada's profile
711 posts in 3387 days
03-02-2009 10:31 AM
Topic tags/keywords: question
Anyone on here make their own sanding belts? I know they are cheap.. why bother??...Cause I’m cheap..LOL so I’ll bother, if I can find out how to succesfully make the joints. I’m thinking Carpet tape and about a 15 degree angle on the splice. Any suggestions would be appreciated.
Thanks
David
11 replies so far
View YorkshireStewart's profile
YorkshireStewart
1130 posts in 3896 days
#1 posted 03-02-2009 02:59 PM
Try it David and let us know. I’m thinking the friction produced heat would soften the tape’s adhesive. What about epoxy glue maybe?
-- Res severa verum gaudium - True pleasure is a serious business. http://www.folksy.com/shops/TreeGems
Craftsman on the lake
2790 posts in 3432 days
#2 posted 03-02-2009 03:11 PM
My belts are 6”x48” where would i get the tough paper that size? Some of mine is cloth backed. Do you have a supply source? And my joints are kind of hard. I’ll bet it’s an epoxy pressed thin.
YorkshireStewart
#3 posted 03-02-2009 03:22 PM
Here's a link that might help David.
#4 posted 03-02-2009 03:28 PM
Hmmm I’m not sure how it’s done?? When looking at my belts 2” x 36” it looks like some kind of adhesive tape. I know that carpet tape once pressed together has a vice is VERY tenacious grip & it’s thin. I was thinking if I did use it I would just leave the backing on the exposed side. I’ll try it then.
As far as a supplier Daniel, you can buy sandpaper in ROLLS pretty well any width and length, from any sandpaper sources. Just look some up on the internet. We have a flea market here and one of the booths sells mega sandpaper in rolls, sheets, pretty wellanything you can think of. That’s where I get mine.
#5 posted 03-02-2009 03:45 PM
Hmmm thanks Stwerart. I visited that site and this is what is posted.
Quote:
I have glued belts together for years for a homemade stoke sander I built. I just cut the joint about 30 degrees on each end then use a belt sander to taper the edges and remove a half inch or so of grit on both ends to avoid a hump at the joint. I glue them together with cynoacrylate, cover the joint on both sides with a sandwich bag, and clamp them with a couple of small blocks and two heavy duty pinch clamps. The glue won’t stick very good to a Ziploc bag or baggie.
I have glued belts together for years for a homemade stoke sander I built. I just cut the joint about 30 degrees on each end then use a belt sander to taper the edges and remove a half inch or so of grit on both ends to avoid a hump at the joint. I glue them together with cynoacrylate, cover the joint on both sides with a sandwich bag, and clamp them with a couple of small blocks and two heavy duty pinch clamps. The glue won’t stick very good to a Ziploc bag or baggie.”
When I looked up “cynoacrylate” it’s super glue. Hmm.. Anyhow I’ve now sent an email to an Ontario based adhesive company asking them what they would recommend.?? If I hear back from them and they have a solution I’ll post it.
#6 posted 03-02-2009 03:55 PM
Sorry Stewart for the typo.. on your name…:)
View Blake's profile
Blake
3443 posts in 3869 days
#7 posted 03-02-2009 08:59 PM
I’m not sure this is a good time vs. money payoff. You still have to pay for the sandpaper… and now the glue… plus the time that it takes to make a sanding belt yourself… for a sanding belt that probably won’t hold up as well anyway… how is this a good idea? What is the actual difference in cost? Sanding belts are cheap. I’d rather slap one on from off the shelf and spend my time woodworking.
-- Happy woodworking!
#8 posted 03-03-2009 04:02 AM
Hmmm Well I’m real cheap..:) I already have rolls and rolls of sandpaper. We have a fleamarket here and a guy has a huge booth of nothing but different types of sandpaper DIRT cheap. So I have the paper, I got way toooo much time on my hands and if all it takes is time and a little glue, tape whatever well…..... I’ll try most anything once.. and 2 more times if I don’t get it right before I convince myself it can’t be done. That’s when I break down.. scrape the moss out of my wallet and head for the store.
Blake
#9 posted 03-03-2009 06:12 AM
Fair enough. Good luck!
View ThorsHammerForge's profile
ThorsHammerForge
1 post in 387 days
#10 posted 04-29-2017 08:28 PM
Well Blake I would agree with you if I could. You see I live in Uganda and almost everything I need to work has to be ordered from overseas. This takes the cost up sometimes as much as 500%. But now after five years our only half decent hardware store started getting roles of sandpaper so like Bigfoot I’m making my own now. Wish I could just go to the store to get them as it sure would be nice!!!
View tomsteve's profile
tomsteve
783 posts in 1214 days
#11 posted 04-29-2017 10:47 PM
8 year old thread here
