spindles checking
Forum topic by jm540 posted 03-01-2009 06:22 PM 890 views 0 times favorited 4 replies Add to Favorites Watch
View jm540's profile
jm540
150 posts in 3658 days
03-01-2009 06:22 PM
Topic tags/keywords: tip question trick lathe turning victorian
I turning some spindles and they are checking about 3-5 days after being turned what do I do?
I noticed on youtube videos people wipe something on them when there finished what is this?
-- jay Rambling on and on again
View Peter Oxley's profile
Peter Oxley
1426 posts in 4114 days
#1 posted 03-01-2009 07:03 PM
What wood species? Kiln dried? How big are the blanks? How big are the finished pieces?
I’m not a turning expert, but some possibilities occur to me … Some species of wood are more prone to checking than others. Turning away a lot of material can releave stresses in the wood, basically removing parts that were holding it together. Also, if the wood has an inconsistant moisture content, removing the outer layers could suddenly accelerate the drying of the inner layers.
I’ve heard that latex paint on the endgrain can help prevent splitting during the drying process, but I don’t know if it would help with checking.
-- http://www.peteroxley.com/woodworking -- http://north40studios.etsy.com --
View lew's profile
lew
12510 posts in 3995 days
#2 posted 03-01-2009 07:19 PM
To add to what Peter said- read somewhere that if you are turning spindles (or anything similar) from a log/branch you should try to avoid having the center growth rings centered in the ends of the spindle.
jm540
#3 posted 03-02-2009 04:54 AM
tulip poplar?
Its green turning 3”x3”x12”
into a
===0===
5/8===( 2 9/16)===5/8
sketch 5/8 spindle with a slight taper to 1” seat for a 2 9/16” ball then back
Peter Oxley
#4 posted 03-02-2009 05:10 AM
Again, I’m not an expert on turning, but I’m going with the accelerated drying of the newly exposed wood theory. You could try coating the whole spindle with something (maybe shellac?) to slow the drying process. Or you could turn it a little oversized, let it dry really well, then turn it down to your finished size.
