Motor for shopmade Belt Sander
Forum topic by interpim posted 03-01-2009 06:20 AM 1219 views 0 times favorited 7 replies Add to Favorites Watch
View interpim's profile
interpim
1170 posts in 3454 days
03-01-2009 06:20 AM
I plan on building a small 4” x 36” belt sander, and am curious as to how big a motor I need to spin it. Plus, if anyone has any ideas on how I could make it “oscillate” that would be awesome :)
-- San Diego, CA
7 replies so far
16274 posts in 4214 days
#1 posted 03-01-2009 04:34 PM
I realize sometimes it’s just fun to make something yourself, but my Delta 4×36 belt/disc sander is one of the most used tools in my shop, and only cost $100 brand new. So unless you can get a motor for little or nothing, I doubt you’ll be saving much money.
I also have a Ridgid oscillating belt/spindle sander. The oscillation does speed up stock removal quite a bit, but you can obtain the same result on the stationary belt by moving the workpiece back and forth yourself as you sand.
View NY_Rocking_Chairs's profile
NY_Rocking_Chairs
510 posts in 3593 days
#2 posted 03-01-2009 05:11 PM
I built the same belt sander and I purchased the motor from Electric Motor Warehouse.
1 1/2hp 3450RPM 56 Frame rigid base Leeson motor 115/208-230volts
It was not cheap, around $300.00
I purchased the belt and pulleys from Grainger and then had a machinist cut a key groove in the drum shaft so everything is keyed.
Good luck,
-Rich
-- Rich, anybody want a peanut?
View marcb's profile
marcb
768 posts in 3669 days
#3 posted 03-01-2009 05:18 PM
I have a 1/3 HP motor on my belt sander. Sanding is something that shouldn’t require a ton of power. Let the sandpaper do the work, don’t press in hard. Otherwise you’ll be replacing your belts a lot more often.
View jm540's profile
jm540
150 posts in 3415 days
#4 posted 03-01-2009 06:14 PM
is this a belt or a drum sander
-- jay Rambling on and on again
interpim
#5 posted 03-01-2009 07:11 PM
Belt Sander… i was thinking of building the one featured in Shopnotes #37
-- San Diego, CA
NY_Rocking_Chairs
#6 posted 03-02-2009 12:05 PM
Somehow I mis-read the question and then wrote the answer up wrong too. That motor I bought is on a 36” drum sander which is use to sand my table tops. Belt sander shouldn’t require that much muscle. Sorry for the confusion.
View BigFoot Products Canada's profile
711 posts in 3389 days
#7 posted 03-02-2009 03:54 PM
I would think that a 1/4 hp would work just fine for that. Normally they spin at 1750 but you can up that easily with pulleys. Garage sales have them all the time for $5.00 or less. I have a bunch of them that I’ve bought from yard sales even some 1/3 rd hp’s for $5.00.
I use them for all sorts of things.. like building 12” disk sanders for my buddies etc. I just turn a mount on my lathe to fit the shaft.. then turn down the other end a little bigger than a face plate and thread it to accept the face plate.
Anyhow.. post it when your done.
Happy sanding!
