Shed for dust collector
Forum topic by woodworkingdrew posted 12-30-2014 03:11 AM 1296 views 0 times favorited 5 replies Add to Favorites Watch
View woodworkingdrew's profile
woodworkingdrew
190 posts in 1783 days
12-30-2014 03:11 AM
Topic tags/keywords: dust collector delta
I just inherited a really nice delta AP300 dust collector from my uncle. Has anyone ever built a storage shed outside there shop for this thing? My garage is cramped and I have a nice big side yard where I can build a small storage shed. What is the longest 4 inch hose I can attach to it? I have listed the specs below. Thanks- Andrew
DELTA AP300 Shopmaster 3/4-Horsepower 680 CFM Horizontal Bag Dust Collector, 120/240-Volt 1-Phase
-- Andrew, California
5 replies so far
View BurtC's profile
BurtC
103 posts in 3305 days
#1 posted 12-30-2014 03:56 AM
I have a small collector installed in a cabinet on outside wall of shop. Works well, but a few things to consider.
-I have switch inside to turn collector on/off. Because it will exhaust heat/AC in shop fast.
-Collector will create a negative air pressure inside shop, so stove or gas heater ventilation is compromised.
Suggest using electric heat.
-I do not use a bag at all on the collector. Exhaust just blows thru a dryer vent to the outside.
-Minimize duct run using solid ducting material. Shorter the better.
woodworkingdrew
#2 posted 12-30-2014 04:06 AM
Burt- Good points. I also have a remote control to turn it on and off, forgot to mention that. My garage has no heat/ a/c so I am good there. The venting is a good idea. Do you have metal or PVC duct work?
View Rob's profile
Rob
704 posts in 3245 days
#3 posted 12-30-2014 07:24 AM
Congrats on the DC but the specs seem relatively weak. Make sure your runs are very short or plan on upgrading to a bigger DC really soon. You’ll want to cluster your tools as close to that DC as you possibly can, or just move one tool up to it at a time.
Make sure you have some return airflow into the shop (perhaps on a different side of the building) to help with the negative pressure issue that BurtC mentioned.
-- Ask an expert or be the expert - http://woodworking.stackexchange.com
View Jim Finn's profile
Jim Finn
2684 posts in 3097 days
#4 posted 12-30-2014 02:52 PM
I built an outside “Closet” to house my dust collector. Works well for me. Keeps any spilled dust outside as I empty the dust bag. Keeps the noise down a lot. I insulated this closet to keep the noise down for my neighbor.
-- No PHD just a DD214 Website> craftingcouple.com
View toolie's profile
toolie
2146 posts in 2803 days
#5 posted 01-04-2015 09:07 PM
not sure if 3/4 hp is sufficient to effectively remove dust. my 1.5 hp delta 50-850 is marginal in that respect.
