1/4" plywood glued into to 3/4"?
Forum topic by HokieMojo posted 02-28-2009 12:20 AM 8333 views 0 times favorited 13 replies Add to Favorites Watch
View HokieMojo's profile
HokieMojo
2104 posts in 3969 days
02-28-2009 12:20 AM
Topic tags/keywords: question plywood veneering
I’ve got a question that I hope someone can help me with. I bought a couple sheets of 1/4” cherry plywood a coupld years ago before I knew anything about woodworking. Now that I’ve learned more, I’ve discovered that some of the projects I planned to use it for would be betterserved with 3/4” plywood.
My questions are:
Will I regret trying to attach 1/2 plywood to 1/4 inch to get to 3/4 inch (I know that plywood isn’t full thickness)
Could I do this without a vaccuum press to clamp the two sheets together
I can’t get 3/4 cherry near me without paying a ton in shipping so thats not much of an option. My alternative is to change the design pretty substantially, and I’d really rather not do that. Any advice would be appreciated.
Thanks!
13 replies so far
View DannyBoy's profile
DannyBoy
521 posts in 4106 days
#1 posted 02-28-2009 12:30 AM
I’m not the expert, but I would think that you can do this. Isn’t this basically veneering?
If I were to do it, I would just make sure every foot or so had some pressure to it. On thinner pieces you can use clamps, but wider ones you can use bricks. I have some cinder blocks hanging around the shop for the same basic use.
-- He said wood...http://hickbyassociation.blogspot.com/
View rickf16's profile
rickf16
392 posts in 3822 days
#2 posted 02-28-2009 12:41 AM
What are you plan on making with the plywood? You could use the 1/4 thickness if you build a frame using 3/4 thick stock.
-- Rick
View 8iowa's profile
8iowa
1591 posts in 4002 days
#3 posted 02-28-2009 12:45 AM
I think this would work. However, in my area it is impossible to find decent, flat 1/2” plywood.
View sIKE's profile
sIKE
1271 posts in 3995 days
#4 posted 02-28-2009 12:57 AM
I have done this several times. I had one project that I was working on and came across a nice 1/4 sheet of Red Oak Ply in the broken bin at the Borg, I just glued it to a piece of 1/2 ply used spring clamps on the edge put some support under the 1/2” ply and placed bricks at even intervals to insure there was enough weight pressing down on the Red Oak ply that it was even. Then cut it to size and it looked beautiful.
This project was the bin organizer from Wood magazine. I made it as a gift for someones new shop. He preceded to paint it all gray. I still cringe when I think about it.
View Julian's profile
Julian
880 posts in 3766 days
#5 posted 02-28-2009 01:30 AM
I just did this for the top and back of the mahogany dresser with secret compartment that I built a few months back. I used 1/4” mahogany ply backed with 1/2” baltic birch ply. If you want it flat, i would suggest using baltic birch ply also. I just made cauls out of 2x construction lumber and made sure to taper the last 10” or so of the ends 1/8” to make sure that the middle would get plenty of pressure while clamping.
-- Julian, Park Forest, IL
View cabinetmaster's profile
cabinetmaster
10874 posts in 3799 days
#6 posted 02-28-2009 02:51 AM
I agree with julian. Use 1/2” baltic birch for the best flatness. We use 1/4” plywood everyday for the finished ends of cabinets. We spray laminate glue on the 1/4” plywood and the 3/4” plywood, let them set for about 2 to 5 minutes and bond together. We then use a non-marring mallet and tap the pieces all over to get a tite bond. Be careful and get the pieces where you want them cause once they touch they are bonded, just like laying laminate on a sub-strate.
View kiwi1969's profile
kiwi1969
608 posts in 3683 days
#7 posted 02-28-2009 03:10 AM
i,ve done with no problems.
View anotherbrick's profile
anotherbrick
73 posts in 3897 days
#8 posted 03-10-2009 12:09 PM
first,putty the uneven area to form a even surface
second,sand the surface you’re going to apply glue,then the glue will be easier to bond
third,use clamps and bricks to give it enough pressure,the more pressure the better,try to make sure the pressure on every area are the same.
-- china
View ajosephg's profile
ajosephg
1880 posts in 3802 days
#9 posted 03-10-2009 12:56 PM
I’ve been told by several cabinet shops that the grain pattern matching, etc. on 1/4 inch plywood is better than that on 3/4 inch, so if that is true that is another reason to use it.
-- Joe
View Moron's profile
Moron
5032 posts in 4134 days
#10 posted 03-10-2009 01:38 PM
I laminate different thicknesses of plywood substrates all the time,
If you dont have contact cement then plain old white, yellow glue will work and if there is concern over proper glue coverage then use a paint roller to apply the glue. You can use paint cans, bricks, concrete block etc to apply pressure and by cutting the sheets into smaller parts (dont forget to cut them bigger then what you actually need) and glue them this way as its easier to handle
Good Luck
View CraigFeuerzeig's profile
CraigFeuerzeig
5 posts in 3611 days
#11 posted 03-10-2009 01:55 PM
Curved cauls will make easy work of this.
-- Bowclamp "good caul"
View Sean Benetin's profile
Sean Benetin
7 posts in 3605 days
#12 posted 03-11-2009 01:36 AM
As long as the piece will be utilized in a way to keep it straight it will work fine. If this is “free floating” or not held rigidly in place it will bow. Laminations need to be made in odd layers 3,5,7, etc. which in turn equals even numbers of glue joints. This is what keeps panels flat (relatively) This is why all sheet goods come in odd numbered layers. When you glue together two sheets it equals and even number of layers and an odd number of glue joints. If you need the piece to remain flat on its own you will need a backer on the opposite side to balance the panel.
-- Fabricators of exquisite custom cabinetry and woodwork http://millworkandmore.com/
View TraumaJacques's profile
TraumaJacques
433 posts in 3741 days
#13 posted 03-12-2009 11:02 AM
Were you thinking of doing 4×8 sheets at a time or individual pieces? 4×8 without a vacume press would be a clamping nightmare.
-- All bleeding will eventually stop.
