Table saw arbor flange stuck
Forum topic by raf posted 02-27-2009 09:42 PM 1946 views 0 times favorited 8 replies Add to Favorites Watch
View raf's profile
raf
23 posts in 3731 days
02-27-2009 09:42 PM
I have a delta contractor saw I got last year. The last time I went to switch blades, I noticed the flange was a little tight. Didn’t think much of it until yesterday, I needed tried to switch blades and for the life of me that thing is not coming out.
I’ve tried everything (that I can think of) short of brute force (don’t really want to do that)...So here is my plea for help :)
Anyone ever have this issue? Is it a result of maybe over tightening the nut when installing the blade?
Any help is much appreciated.
8 replies so far
View Woodchuck1957's profile
Woodchuck1957
944 posts in 3727 days
#1 posted 02-27-2009 09:46 PM
Is there a way you can turn it off ? Is the blade lose ?
View raf's profile
raf
#2 posted 02-27-2009 10:25 PM
I can only do about 1/2 turn on the flange before it gets stuck. I managed to get it to move about 1/4” away from the blade, so the blade is lose. The nut goes on and off without a problem, so whatever happened… it only affected the flange.
Thanks.
Woodchuck1957
#3 posted 02-27-2009 10:31 PM
Keep workin it, maybe the burr or whatever it is will wear away. Other than a couple strap wrenches I don’t know what else to tell you without scratchin something up.
View raf's profile
raf
#4 posted 02-27-2009 11:20 PM
great thanks….good idea on the strap wrench…I’ll have to try that out
View TomHintz's profile
TomHintz
207 posts in 3361 days
#5 posted 02-27-2009 11:56 PM
I would try cutting a couple wooden wedges to put between the washer and blade, coming from opposite directions and try tapping them in a little at a time to “walk” it off. It might help overcome a burr at the center hole which I agree is likely the problem. I had that on an old Delta and just cleaned it up with a fine rat tail file. It just needed a good touch here and there to round the edge just a little and it worked fine ever after.
-- Tom Hintz, www.newwoodworker.com
View raf's profile
raf
#6 posted 02-28-2009 03:04 AM
Got it!!! I managed to get that thing out after about a half an hour…I’m going to file it down so hopefully that doesn’t happen again. Thanks for all the responses.
Woodchuck1957
#7 posted 02-28-2009 04:38 AM
How did you get it ?
View raf's profile
raf
#8 posted 02-28-2009 04:56 AM
sprayed some WD40…then from the back of the saw I grabbed a hold of the flange with my left hand (with a non-slip glove) and with my right hand I moved the drive belt back and forth until I was able to get a full turn. Once I did that, it just came lose.
Thanks for your help.
