measuring board feet when purchasing rough sawn lumber
Forum topic by robdew posted 02-27-2009 08:45 PM 10597 views 0 times favorited 11 replies Add to Favorites Watch
View robdew's profile
robdew
86 posts in 3618 days
02-27-2009 08:45 PM
When I am purchasing rough-sawn lumber that is cut to a variety of thicknesses, what is the usual convention for board thickiness for BF calculation?
I know milled lumber usually rounds up 13/16 or 7/8” to 1”. Does rough sawn do the same or is it actual thickness?
I am considering purchasing some rough sawn lumber from someone locally who usually doesn’t deal with this (because the price is very good) and hence it’s not all 4/4 or 8/4, etc.
As usual I can’t figure out what the appropriate forum is for this question, so I will ask it here.
11 replies so far
View mountainsky's profile
mountainsky
29 posts in 3301 days
#1 posted 02-27-2009 09:11 PM
If no surface is planed, you should be buying actual thickness….........
16272 posts in 4122 days
#2 posted 02-27-2009 09:16 PM
If the lumber you are looking at is rough sawn to 1” thick, you wouldn’t round up. A board that is 1” x 12” x 12 feet long would equal 12 board feet. The reason surfaced lumber is actually smaller than its board foot calculation is because that calculation is based on the rough sawn size.
Am I saying that clearly enough?
View Darell's profile
Darell
434 posts in 3498 days
#3 posted 02-27-2009 09:24 PM
thickness x width x length divided by 144 equals board feet. Keep in mind what Charlie said about rough sawn size.
-- Darell, Norman, Ok.
View PurpLev's profile
PurpLev
8534 posts in 3552 days
#4 posted 02-27-2009 09:31 PM
when lumber is being measured for BF it is measured by the rough sawn surface – so when you buy rough sawn lumber you pay for it’s current size…
If you buy lumber that was milled – you’d be paying by it’s ‘original’ rough sawn size – thats why you get ‘less’ material for a given measurement when it’s pre-milled.
27251 posts in 3725 days
#5 posted 02-27-2009 09:37 PM
One additional thought on the subject is that rough sawn 4/4 stock is usually sold at 1 1/8” in thickness and accordingly, 8/4 rough stock is usually 2 1/4” thick. For the purposes of calculating bf simply use Darell’s formula and substitute 1 for thickness of your 4/4 stock and 2 for 8/4 material. And, this formula assumes that both the width and length measurements are in inches.
robdew
#6 posted 02-27-2009 11:04 PM
this cleared it all up thanks!
View David Freed's profile
David Freed
113 posts in 3571 days
#7 posted 02-28-2009 05:26 AM
“One additional thought on the subject is that rough sawn 4/4 stock is usually sold at 1 1/8” in thickness and accordingly, 8/4 rough stock is usually 2 1/4” thick.”
That is only true if it is green, and even then that is on the thick side. If it measures that thick after it is dried, it is a miscut.
This was discussed a few days ago here – http://lumberjocks.com/topics/6510
-- David, Southern Indiana
View HossMan's profile
HossMan
42 posts in 3622 days
#8 posted 02-28-2009 02:35 PM
”...thickness x width x length divided by 144 equals board feet.”
I just want to clarify that this formula works if the length is measured in inches. If length is in feet, then the formula is thickness x width x length divided by 12 (twl/12)
kinda nit-picky, I know…....
View HeirloomWoodworking's profile
HeirloomWoodworking
238 posts in 3643 days
#9 posted 02-28-2009 03:32 PM
I wonder if I might add a question to this thread.
In my area there are no local mill sources. I have always purchased my hardwood S3S (surfaced face, back and 1 edge) from the small local lumber yards. I have used a surface planer (13 1/2”) to plane my materials smooth and consistant.
I am considering venturing into purchasing “rough” lumber.
When buying rough lumber will my existing surface planer properly plane and true this material?
I have also seen several terms used for rough lumber…hit & miss planed. skip planed etcetera.
Thanks in advance for your replies & advise.
Trev
-- Trevor Premer Head Termite and Servant to the Queen - Heirloom Woodworking
View Boardman's profile
Boardman
157 posts in 3665 days
#10 posted 02-28-2009 04:20 PM
Heirloom – The planer will only render the two surfaces PARALLEL. If you plane both sides of a bowed board you’ll end up with a bowed board with 2 nice parallel sides. You’ll need a jointer to render it truely flat before planing – you only need to get one side flat and the planer will take care of the other side.
Hit/miss or skip planed means they ran both sides thru a planer, but don’t guarantee a 100% clean surface on either side. To what degree they’ll be cleaned up varies by supplier. I get skip-planed oak from a lumber yard and most of the time it’s completely cleaned up at about 15/16th. But – it won’t be flat necessarily.
Purely “rough sawn” lumber has not been planed at all.
View miles125's profile
miles125
2180 posts in 3909 days
#11 posted 02-28-2009 04:37 PM
Most all projects you see in lumberjocks call for wood to be surfaced to ensure its flatness. Nobody but the end user does this. So it makes sense to buy boards in the rough to get maximum plumpness for this task.
-- "The way to make a small fortune in woodworking- start with a large one"
