Mule TS fence
Forum topic by Neodogg posted 274 days ago 291 views 0 times favorited 9 replies Add to Favorites Watch
View Neodogg's profile
Neodogg
89 posts in 326 days
274 days ago
Does anyone have a Mule Cabinetmaker fence system? Seems reasonable priced for under $200 for 50” & comes with a lifetime warranty? I seen/heard about the T2 for $150 @ bLowes, but I believe it’s got plastic parts that will break in due time. The Vega’s and Bes seem to be a bit much for my pocket book at the current time. I guess I could “make” one somehow?
-- If you can't fix it with a hammer, you've got an electrical problem!
View jeh412's profile
jeh412
131 posts in 274 days
274 days ago
Hi Neodogg … New member and I was browsing the home page and saw your question.
I bought a Mule Cabinetmaker fence system and router table for my old Craftsman TS in 2001 or 2002. It was the only aftermarket fence I could find for that saw since it had just a 23-inch deep top. Anyway, the fence system is pretty well made and when I first installed it, it seemed very good. Easy to adjust, solid, etc., etc. However, the front rail (aluminum) started to wear after 3-4 years. Still worked well but wasn’t as smooth. Not long before I sold that saw last fall I had a piece of 1/4 inch ply kick back and it broke the cursor. I emailed J. Withrow, company owner, to get a replacement. That was at the end of October. Reply said it was covered by warranty and he’d get it to me right away. Two weeks passed, no cursor, another email and he said the part had been out of stock but he had them again and would get it right out to me. I sold the saw at the end of November but told the buyer that I would forward the cursor when it arrived. Despite many emails to J. Withrow I never got the cursor and haven’t even had replies. I wasn’t nasty in my messages but was firm in letting him know that I wasn’t pleased and would appreciate a reply. In my last message I told him I assumed he had fallen of the face of the earth and was done with him.
Bottom line, for me, it was a decent product for the price but showed wear faster than it should have and there is absolutely no customer support. I wouldn’t buy Mule again and wouldn’t recommend them to anyone else.
John
-- John, co-owner Sawdust 'n Stitches
Neodogg
274 days ago
solid input, so that’s:
Good – 0
Bad – 1
View marcb's profile
marcb
705 posts in 572 days
274 days ago
Not much plastic on the T2, maybe part of the handle.
View Timbo's profile
Timbo
288 posts in 463 days
273 days ago
I recently purchased the Mule Cabinetmaker fence system from Rockler’s in Pittsburgh Pa. (it was on clearance for $60) so you might check with them, they may have another. When I put it on it was missing the stick on rule tape and Rockler’s promptly sent one. I also had an additional problem with the fence and needed replacement parts, I called Mule Cabinet (never an answer or call back) and emailed several times with no response. I again called Rockler’s to hopefully put some pressure on, which worked and I did get email response and finally received the replacement parts a month and a half later….
Overall I do like the fence better than what I had but can’t recommend Mule cabinet, due to the lack of support.
If I had to do it all again (which I may) I would consider what fellow LJ Hutch did.
http://lumberjocks.com/jocks/Hutch/blog/2740
-- Tim: Remember, if it doesn't say Binford, someone else made it.
View knotscott's profile
knotscott
532 posts in 274 days
272 days ago
Neodogg – I used both the Delta T2 and the Mulecab on a friend’s saw. The Mulecab was a big step up from the stock fence on his old CMan contractor saw, but compared to the T2, Vega, and Biese, it’s not as robust. There was a bit of deflection at the end, and you’ve got to roll it fully off the rails to remove it. It does have t-slots and some nice accessories for it, and a lot of people are really happy with it. My friend ended up with a Biese that he loves…the T2 is much more like a “Biese Lite” than the Mulecab.
AFAIK, the T2 is steel where it counts, and only the handle is not….it’s pretty stout for a $150 fence, but I don’t believe they offer a 50” rip version, though you could probably slide the rails to the right to gain more than the stock 30”.
View Steve2's profile
Steve2
48 posts in 469 days
272 days ago
The Mule fence is a great product. I bought mine a year ago and their small company service can be a little limited but it is not a big deal. The only “plastic” parts are two nylon rollers in the track that are in use only when it glides – they do not take any wear or cause any problem. I bought a used Unisaw and transferred my Mule instead of the Beis fence because I don’t want to give it up. Great product.
-- Regards, Steve2
View Emeralds's profile
Emeralds
155 posts in 461 days
272 days ago
I played around with a number of after market fences and decided that for twice the money there simply wasn’t a product that could out preform the T2. My old Craftsman contractors TS has been my work horse since I started and I decided to convert it to a hybred by building it into it’s own cabinet. Upgrading the fence was absolutely essential as the fence that came with the saw was virtually useless from day one. All in all the T2 has been a solid preforming tool. It has all of the necessary adjustments and there is actually very little to distinguish it from it’s Biesemyer conterparts. I think you’ll be very pleased with it although admittedly I’m sure I would like a Powermatic PM2k better … :)
-- JMP
marcb
247 days ago
I wanted to follow up on this as I actually took a little time to look over my T2, and even compare it to the Bies that I have.
1) Not counting the wear strips/glides that are UHMW the only plastic on the fence is the knob on the handle (handle stem and cam are both steel), the adjustable cursor, and the end caps on the aluminum faces. Magnets stick to everything else that matters except the aluminum faces
2) The T2 fence seems heavier than my Biesemeyer by a little bit. And the Bies is longer. I’m not sure what the Manufacturing process on the Bies is, it might have a better grade of steel, but they tried to make up for that by beefing the T2 up in other ways then.
View Eduardo Rodriguez's profile
Eduardo Rodriguez
34 posts in 269 days
247 days ago
I make my own fence, based in Biesemeyer design. Visit this link:
http://home.comcast.net/~jaswensen/machines/fence/fence.html
Before I build it, I change impressions with other people that help me a lot realizing how to do that. Is good for ego, and works great.
-- Tempus fugit...better work wood!!!
