Cutting a circular top
Forum topic by ezgnann posted 12-29-2014 03:04 PM 990 views 0 times favorited 12 replies Add to Favorites Watch
View ezgnann's profile
ezgnann
30 posts in 2494 days
12-29-2014 03:04 PM
Topic tags/keywords: question jig
Recently, I acquired some pieces of 1 3/4 oak and I want to make a circular top out of it. What is going to be the best way to cut the top?
1. I have looked into a circle cuttlng jig and spiral bits for my router. Bits that cut to 1 3/4 are a bit expensive (pun intended) but I am willing to do it if that is best.
2. I could rough cut it with a jig or band saw, but I will still have a clean the edges with a router bit.
3. What else am I missing?
Thanks in advance for your guidance.
-- Woodworking is cheaper than psychotherapy and better for me than whiskey
12 replies so far
View joey502's profile
joey502
519 posts in 1389 days
#1 posted 12-29-2014 03:12 PM
I don’t see that you are missing anything. Cutting close to the line before routing sounds like a good plan. Just remember not to climb cut.
I do not see any reason the bit has to be spiral. Spiral would be better but it is not a must. The risk of tear out lessens with the spiral bit but a straight bit would get it done.
View ChefHDAN's profile
ChefHDAN
1007 posts in 2720 days
#2 posted 12-29-2014 03:18 PM
If you have the band saw, then a circle cutting jig ifor the BS is the best way to go. There are loads of plans on google, that can get pretty complicated, but all you really need is a base, a cleat into your miter slot and a pivot point at the radius. I’ve got one hanging in the shop from a 24” tabletop that I made just out of scraps, and just use a screw through the bottom for the pivot, if I made more circles, I’d consider making a fancier adjustable one.
Check out BFD's project
ezgnann
#3 posted 12-29-2014 03:42 PM
@chefdan – How do you deal with blade drift and deflection on the BS? What size blade did you use for your 24 inch table top?
@joey502 0 What do you mean by climb cut?
View jmartel's profile
jmartel
7626 posts in 2021 days
#4 posted 12-29-2014 03:44 PM
Another thing you can do is to go as deep as you can with a spiral bit and then use a flush trim bit with the bearing riding on the surface that the spiral bit cut. That lets you cut it from both sides so you only need 7/8” on either side to cut.
ezgnann
#5 posted 12-29-2014 04:17 PM
I like the half spiral/ flush trim approach. Realistically, what is the most I should remove at one time with the flush trim bit? Assuming I remove the mass of material with the bandsaw or jigsaw and leave the finishing cut to the router, there still would be quite a bit of material to be cut.
jmartel
#6 posted 12-29-2014 04:19 PM
I generally like to keep passes on the router 1/8”-1/4” at a time. Usually results in less chipout.
View JAAune's profile
JAAune
1772 posts in 2187 days
#7 posted 12-29-2014 07:44 PM
I use a bandsaw circle-cutting jig but the pivot point slides back and forth. There’s an article in Fine Woodworking.
Michael Fortune Bandsaw Circle Jig
That will get a perfect circle very quickly and won’t need much cleaning. Bandsaw drift and deflection won’t happen on a properly-tune saw that has a good blade installed.
View paxorion's profile
paxorion
1107 posts in 1916 days
#8 posted 12-29-2014 08:06 PM
Two thoughts:
  1. As others have suggested, cut close to the line, but flush up with a router
  2. Buy/make a circle cutting jig for your router and make progressively deeper passes.
Woodworkers Journal is featuring a circle cutting jig for jigsaws and routers in this month’s issue.
https://www.youtube.com/watch?v=4D08zHvtlcg
-- paxorion
ChefHDAN
#9 posted 12-29-2014 11:05 PM
1) Tune the saw, and watch the snodgrass tuning method, with it I don’t get any drift,
1.5) Use a good blade, I Like timberwolf and wood slicer
2) 3/8
- ezgnann
View Sawdust4Blood's profile
Sawdust4Blood
393 posts in 2892 days
#10 posted 12-29-2014 11:29 PM
What diameter circle are we talking about? At an 1-3/4 thickness I’m assuming that you’re thinking about a fairly large circle. I built my bandsaw circle cutting jig based on Winky's with some minor modifications. That allows me to cut circles from as little as 3 inches out to about 6 feet in diameter (using supplemental support). The size circle you’re making determines the size blade you need to use. Small circles need a small blade but that leaves a rougher edge. For smaller circles, I use a similar jig on my sanding station to smooth out the edges. For large circles, you can honestly just sand off the saw marks free hand and the very minor variations from a perfect circle won’t be noticeable to the eye unless you really go wild with the sander.
-- Greg, Severn MD
View Radu's profile
Radu
330 posts in 2914 days
#11 posted 12-30-2014 12:23 AM
Here is link to a Youtube video – cut a circle on table saw http://youtu.be/Wxbzrf4z_cg
Check it out – it might work for you.
View pintodeluxe's profile
pintodeluxe
5544 posts in 2684 days
#12 posted 12-30-2014 12:36 AM
I use a circle cutting jig and a plunge router. With a spiral bit I don’t worry about pre-cutting close to the line. I just cut the circle out in 3-4 light passes. The jig ensures the circle remains true.
