mdo plywood
« back to LumberJocks.com Site Feedback forum
Forum topic by clint posted 273 days ago 172 views 0 times favorited 3 replies Add to Favorites Watch
View clint's profile
clint
9 posts in 436 days
273 days ago
has anyone used mdo for a router table top nice smooth finish and pretty tough material how does it compare to laminate any advise please thanx clint
View roman's profile
roman
1125 posts in 790 days
273 days ago
is mdo the same as mdf?
20733 posts in 719 days
273 days ago
Clint, I do not mean to hijack your post but here is a response for Roman:
MDO and MDF are different materials. MDO stands for medium density overlay. It is a plywood product, with a paper face overlaid on the plywood substrate with an exterior grade (usually) phenolic adhesive. MDO is designed to have a smooth paint receptive surface. One or both faces can be faced with paper, and is found in 4’ x 8’ sheets from 3/8” to over an inch in thickness.
MDF is an engineered wood product formed by breaking down softwood into wood fibers combining it with wax and a resin binder, and forming panels by applying high temperature and pressure. It is made up of separated fibers, (not wood veneers). It is normally found in 49”x97” sheets.
roman
273 days ago
Thanks Scott…............in others words, MDO is “sign board”
Knowing that I would say that MDF is a better bang for the money.
