Identifying an Interesting Curved Symmetric Solid
« back to Coffee Lounge forum
Forum topic by SteveK1 posted 12-28-2014 06:02 PM 734 views 0 times favorited 2 replies Add to Favorites Watch
View SteveK1's profile
SteveK1
2 posts in 1216 days
12-28-2014 06:02 PM
Hello, I was recently given a very cool curved solid made from maple and walnut. I recall seeing its construction described on a woodworking blog in the last year or two, but without being able to recall the name for this shape, I am unable to find the blog. Any help identifying the name of this solid would be appreciated. Thanks.
Steve
2 replies so far
View Dark_Lightning's profile
Dark_Lightning
3146 posts in 3079 days
#1 posted 12-28-2014 07:51 PM
I can’t tell without more pictures, unless every shot around at this elevation is the same (except for the obvious color changes). Is the base round or some sort of oval?
-- Random Orbital Nailer
SteveK1
#2 posted 12-28-2014 10:13 PM
The piece is symmetric, and I think of the outline to be very similar to bringing two identical disks together whose faces are 90 degrees to each other. If you hold your two open hands in front of you, one with the fingers pointing up and the other with the fingers pointing away from you, and move your hands come to each other, that approximates the orientation of the two disks.
I can also supply a short video if that helps. I think I first read about this somewhere on the Lumberjocks wesbsite. Thanks.
Two additional photos:
