Small Compressor for Cleaning
Forum topic by Mark2457 posted 12-28-2014 02:26 PM 939 views 0 times favorited 11 replies Add to Favorites Watch
View Mark2457's profile
Mark2457
49 posts in 1460 days
12-28-2014 02:26 PM
Hi All
i have bostitch compressor that works great with my framing nailer and smaller guns, but it is pretty heavy, loud and has a really stiff hose. I’m looking for something small with retractable hose (can obviously buy separately) that I can just leave on and use for cleaning (miter tracks, inside saw cabinet, etc.) and maybe a brad nailer.
Are there any that can be left on all the time (or at least all the time I’m in the shop) that don’t need draining everyday? Do these exist?
Was thinking about spending about $100 for one
Footprint is important as my shop is very small. Ideally, I’d like to wall mount it
Thanks
Mark
11 replies so far
View mtenterprises's profile
mtenterprises
933 posts in 2569 days
#1 posted 12-28-2014 02:33 PM
Use a Nebulizer., one of those medical units that administers liquid medication. You can often pick these up free or cheap. Seen them at the thrift stores for like under $10. Great for blowing off things.
-- See pictures on Flickr - http://www.flickr.com/photos/44216106@N07/ And visit my Facebook page - facebook.com/MTEnterprises
Mark2457
#2 posted 12-28-2014 02:58 PM
- mtenterprises
Thanks for tip. Will see what I can find
MrUnix
6201 posts in 2075 days
#3 posted 12-28-2014 06:03 PM
I leave my C-man (made by DeVilbiss) compressor on 24×7 out in the garage so it’s ready to go whenever I need it. I only drain the tank maybe once a year if I remember.. sometimes longer. Only problem I have is when it startles the crap out of me kicking on when I’m not expecting it :)
Mark2457
#4 posted 12-28-2014 08:10 PM
I leave my C-man (made by DeVilbiss) compressor on 24×7 out in the garage so it s ready to go whenever I need it. I only drain the tank maybe once a year if I remember.. sometimes longer. Only problem I have is when it startles the crap out of me kicking on when I m not expecting it :)
- MrUnix
Thanks Brad. Good to know. I’ll assume I can do the same with anything I buy. If it’s under $100, I don;t mind if I have to replace after a few years. (Shop will have changed a lot by then :-))
View dhazelton's profile
dhazelton
2657 posts in 2173 days
#5 posted 12-28-2014 08:54 PM
The Porter Cable pancake is to me one of the better bang for the buck compressors, and Lowes and HD had it for $90 or so this holiday season. I really would like the Makita oil compressor but at 70 lbs I can’t see moving it around that much. The PC is only 30-35 lbs and can run a framing nailer.
View Bill White's profile
Bill White
4823 posts in 3837 days
#6 posted 12-28-2014 11:03 PM
I will NEVER leave my compressors on all the time (any more). Had one start leaking from the pressure relief valve one night. Woke up to a shop filled with smoke, and a very hot compressor.
Just too many chances for a real problem.
Bill
-- bill@magraphics.us
MrUnix
#7 posted 12-29-2014 12:01 AM
Thanks Brad. Good to know. I ll assume I can do the same with anything I buy. If it s under $100, I don;t mind if I have to replace after a few years. (Shop will have changed a lot by then :-))
I think you should get a little more than just a few years.. I plugged mine in at it’s current location over 12 years ago and only turn it off on the rare occasions when I do drain the tank. If you are paranoid about something happening to the compressor like Bill suggests, another alternative (besides the small portable compressor) is to get an external air tank. I have an 11gal one that I keep filled up and use for light cleaning as well as a portable air supply for pumping up tires and other stuff away from the house:
I put a quick connect on the tank and added a 20 foot hose (also with a quick connect) which makes it quite handy for lots of stuff.
View Loren's profile
9774 posts in 3524 days
#8 posted 12-29-2014 12:51 AM
I have an old fire extinguisher I keep in the shop. I have
it full of water, but it holds air to compress the water
to make it squirt out. It holds the air charge for
a really long time, so it stands to reason it could
be used to spray compressed air only and of course
it’s made of stainless steel in order not to rust out.
Mark2457
#9 posted 12-29-2014 04:48 PM
Bill
- Bill White
I don’t mind turning it on and off, just don’t want hassle of draining it every time I use it
Mark2457
#10 posted 12-29-2014 04:48 PM
it s made of stainless steel in order not to rust out.
- Loren
How would you refill it (with air)?
Mark2457
#11 posted 12-29-2014 04:55 PM
I think you should get a little more than just a few years.. I plugged mine in at it s current location over 12 years ago and only turn it off on the rare occasions when I do drain the tank. If you are paranoid about something happening to the compressor like Bill suggests, another alternative (besides the small portable compressor) is to get an external air tank. I have an 11gal one that I keep filled up and use for light cleaning as well as a portable air supply for pumping up tires and other stuff away from the house:
- MrUnix
looks pretty good. Just need to find a suitable hose and some kind of nozzle with a trigger for cleaning
