How do you make this?
Forum topic by Rob posted 277 days ago 647 views 1 time favorited 10 replies Add to Favorites Watch
View Rob 's profile
Rob
197 posts in 566 days
277 days ago
I was looking for some inspiration for making a valet and came across this beautiful box. I doubt I will make this because I would rather come up with my own design however I find myself intrigued with how this was done. Can someone explain this to me? Was a square box built first and then the sides were curved on perhaps a beltsander? If that was the case then how do you explain the drawer? I know there are a few ways to skin a cat but I’d like to hear some of them. What do you think?
View ShannonRogers's profile
ShannonRogers
370 posts in 687 days
276 days ago
If the interior of the case is flat then I would think the box was built square and then rounded with a bandsaw. the interior of the drawer would be made square and reference against the square interior of the cabinet, but the drawer front would be cut to match the outer curve. That how I would do it anyway, I too would love to hear what others think.
-- Check out my blog and podcast "The Renaissance Woodworker" at www.rogersfinewoodworking.com/blog
View interpim's profile (online now)
interpim
455 posts in 357 days
276 days ago
I saw a box similar to this in FWW issue #139
He used a small block plane to knock down the sides, then a profiled scraper to come to the final shape.
another one in FWW 107 using a router jig to make the profile.
and in FWW 90 they used curved molding and applied a veneer.
-- San Diego, CA US Navy
View leonmcd's profile
leonmcd
198 posts in 870 days
276 days ago
You could create it as you said with a belt sander after the box is built. You could also shape it with a plane or you could also use a router planeing jig with curved rather that flat rails.
I’m assuming that the curve is only on the outside so that the drawer front is pretty thick. If you want a thinner drawer front you would have to work the inside of the drawer front BEFORE you created the drawer. You could cut a cove on the inside of the drawer front using a table saw.
-- Leon -- Houston, TX - " I create all my own designs and it looks like it "
View Chiefwoodworker's profile
Chiefwoodworker
65 posts in 277 days
276 days ago
I don’t believe it is just a box. The ebony handles are for the lid (top) and I think a draw (bottom). If I were building it I would start the same way I make ogee feet. I would start with a long board and rough shape it with a table saw, band saw and finally a plane and sandpaper. See http://www.srww.com/six_pane_oak_hutch/images/Shaping%20With%20Block%20Plane.jpg . Then I would cut it into pieces and join them. See http://www.srww.com/six_pane_oak_hutch/images/Six%20Feet.jpg and http://www.srww.com/six_pane_oak_hutch/images/Feet%20Ready%20For%20Glue%20Up.jpg .
-- Joe.....
View Rob 's profile
Rob
276 days ago
I think you guys are right about the inside of this box being flat as you can see in the picture below. I think Joe is on the right track with making one piece all the same first. I think that would give you an advantage in uniformity however I imagine it presents some difficulty for glueing up. I love the tray that lifts out as the lid rises. Reminds me of a tackle box in a way – just way nicer!
25806 posts in 1299 days
275 days ago
So when are you going to start. A nice design
View Rob 's profile
Rob
275 days ago
Not until I understand it better Karson. I bet I would build it square first and then think it looked pretty good that way and not go any further. Perhaps I should build two at once so I have some insurance.
View jjraybur's profile
jjraybur
39 posts in 241 days
240 days ago
Here is a very similar box (without the drawers) made from cocobolo with the construction details:
http://sawmillcreek.org/showthread.php?t=99047&highlight=cocobolo
http://sawmillcreek.org/showthread.php?t=99719&highlight=cocobolo
-- Jeremy, Baton Rouge, LA - rayburnfinefurniture.com
View Gary's profile
Gary
597 posts in 332 days
240 days ago
I did something simialr one time. I ripped the wood on a 12 degree cut, 3” down from the top then inverted it. It gave me a shape similar to that box only, since I inverted only one peice, it was just angled in at the top, not the bottom. Could have rounded it easily by sanding.
-- Gary, DeKalb Texas
View jleiwig's profile
jleiwig
41 posts in 669 days
239 days ago
just searching around fine woodworking website and found this free plan
http://www.taunton.com/finewoodworking/FWNPDFfree/011139060.pdf
I think it might be just the ticket for what your trying to do.
-- I intend to live forever, or die trying..........Justin, Ohio
