clamps for cabinet assembly
Forum topic by Vjeko posted 02-24-2009 09:47 PM 3241 views 1 time favorited 3 replies Add to Favorites Watch
View Vjeko's profile
Vjeko
135 posts in 3283 days
02-24-2009 09:47 PM
Topic tags/keywords: question clamp
Hi,
just wanted to check what you’re using /what’s most practical when clamping cabinet
sides for assembly (clamping pieces at right angles) – metal squares
like ones sold at woodpeckers
http://www.woodpeck.com/clampingsquare6.html, something like the bessey ws6
(http://www.pentagondirect.com/p/bessey-ws6-ws6-angle-clamp)
or something you made yourself ?
-- Vjeko Balas - Croatia
3 replies so far
View Greg Wurst's profile
Greg Wurst
794 posts in 3701 days
#1 posted 02-24-2009 10:31 PM
I’ve got the WS6 style clamp, but it’s only good for smaller boxes. For larger cabinets I use shop-made plywood corner clamps. I’ll post a picture of what I’m talking about here once I draw one in Sketchup.
Greg Wurst
#2 posted 02-24-2009 10:47 PM
Here’s, what I’m talking about. You can make them any size you need and get 2 clamp aids out of a square piece of 3/4” plywood. Just cut the flat surfaces wide enough for your clamps. The hole is for mounting or using a spring clamp for additional support. These particular clamps I drew are 12”x12” cut in half diagonally.
Vjeko
#3 posted 02-25-2009 01:13 PM
Thanks Greg ! OK, so WS6 is off the list at least for the cabinets.
I really got to get into using sketchup – really helps.
